uneven front camber on stock suspension
Old Apr 6, 2011 | 06:34 AM
go kart's Avatar
go kart
Default uneven front camber on stock suspension
for some reason my driver's side front camber is at 0.8 and my passenger side front camber is at 1.2. the toe is in the middle for both sides. is there any bushing that might be the culprit for this?
also, how long should i wait for my springs to settle before i get an alignment? i havent put them on yet
Old Apr 6, 2011 | 08:12 AM
terrasmak's Avatar
My car did the opposite, it happens. Usually its from compression arm bushings, they also screw up the camber. Most like the compression arm bushing is shot, if not it will be in 5k miles after you lower it. Also look at the LCA bushings, it is common for them to tear.
Old Apr 6, 2011 | 07:53 PM
go kart's Avatar
go kart
the car was lowered before i got it so im pretty sure the bushings are already torn. ive already put some whiteline bushings in both LCAs so i guess ill look into getting some of those new energy compression bushings. i doubt it matters if i mix and match brands of poly bushings? i just want to find the culprit bushing so i can fix that one first.
Old Apr 9, 2011 | 01:26 PM
go kart's Avatar
go kart
bump, anyone else know what could be causing this?
Old Apr 9, 2011 | 03:19 PM
XSpeedAddictX's Avatar
XSpeedAddictX
Where could you buy the bushing mentioned above?
Good luck OP
Old Apr 9, 2011 | 04:33 PM
go kart's Avatar
go kart
look for the energy suspension front arm kit, its sold in the vendor marketplace
Old Apr 9, 2011 | 06:30 PM
JDMStanced's Avatar
JDMStanced
a year ago, before my alignment was -.12 and -.09
After alignment, it changed to -.11 and -.10 lol
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
samansharif
Sep 25, 2015 12:31 PM
