exedium rear camber arms
Old Apr 13, 2011 | 10:51 AM
reds's Avatar
reds
Default exedium rear camber arms
anyone use or have any feedback on these? i can't seem to find any info on them at all
Old Apr 13, 2011 | 12:24 PM
terrasmak's Avatar
Made in china where all the other cheap arms are. Probably ok for use, for $80 its cheap to find out.
Old Apr 13, 2011 | 07:53 PM
R350Zz33's Avatar
R350Zz33
i won them on ebay for a dollar the company refunded me and said there was a mistake and there were non in stock
Old Apr 15, 2011 | 03:39 PM
reds's Avatar
reds
Ok well they were cheap so I didn't mind takin the hit too much...but these are advertised on vex motorsports and the description for them is wrong. It states it will put camber back in spec for lowered cars up to 2" but these arms are made to add camber..go figure. So I'm sending them back and getting a refund....live and learn I guess
Old Apr 16, 2011 | 01:23 AM
winchman's Avatar
winchman
If the wheel is tilted in at the top, the camber is negative. That's what you get when you lower the car with the stock arms.
You need to shorten the lower arm to get the wheel closer to being vertical (going from too much negative to just a little negative), so I suppose that would be "adding" camber.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
