Broken Break Pistol Bolt - help!
Old May 3, 2011 | 08:25 AM
dreckis604's Avatar
dreckis604
Default Broken Break Pistol Bolt - help!
Was changing my rotors and break pads.... almost completed everything on the passenger side when i was tightening the break caliper piston i broke the bolt inside and its now stuck inside. What should i do?
How can i remove this bolt? Also what is the replacement party I need to order?
Old May 3, 2011 | 08:37 AM
terrasmak's Avatar
Broken break, isnt that redundant?
There is no bolt on the BRAKE piston
Old May 3, 2011 | 09:00 AM
dreckis604's Avatar
dreckis604
there are two bolts which hold on that piston to the caliper.... with the rubber housing connected to it... so yes there are 2 bolts. its called sliding pin bolt
Old May 21, 2011 | 09:56 PM
Nebiros's Avatar
Nebiros
You will have to take out your other bolt and remove the caliper from the mounting bracket. You will have to buy a new caliper slide and bolt.
The way it is setup is: Brake caliper mounting bracket, brake caliper slides, and the brake caliper. The piston is located inside the brake caliper. Calling parts their correct name will help your parts person know what you are talking about.
Old May 22, 2011 | 02:56 AM
winchman's Avatar
winchman
A competent machinist should be able to get the broken bolt out without damaging the part.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
nanotech
Oct 2, 2015 05:02 AM
Dymsi
Sep 29, 2015 11:32 AM
