spanner question
Old Jul 24, 2011 | 05:32 PM
kihun's Avatar
kihun
Default spanner question
i have stance pro coilovers but i cant find my damn spanners. does anybody know any spanner works universally? i see few on ebay but they are different brands. or if anybody is selling it on here, let me know thanks.
Old Jul 24, 2011 | 08:50 PM
shakuya88's Avatar
shakuya88
Totally unrelated but I saw this and honestly thought it was a "spinner question" since i read it quick at first....lol
Old Jul 24, 2011 | 08:56 PM
Chi-TownWarrior's Avatar
Chi-TownWarrior
Call Stance and order new ones.
Old Jul 26, 2011 | 11:52 AM
Junkster's Avatar
Junkster
I didnt have the spanners for my megans for a while after i installed them (PO couldnt find them for almost a month before he gave them to me). IN the meantime i was just using a flathead and a hammer to knock the rings loose and to tighten them.
Even after i got the spanners i still use this method lol...makes life so much easier if you ask me...spanner wrenches are anoying as fawk to use...
as a side note just call stance and ask them for the dimensions of their spanner wrenches. Once you get them you can search on ebay for adjustable spanners...just a thought.
Old Jul 26, 2011 | 11:55 AM
jduet's Avatar
jduet
Only $25
http://stance-usa.com/sus/products/h...anner-wrenches
Old Jul 26, 2011 | 12:07 PM
sry110's Avatar
sry110
Originally Posted by jduet
This.
In my experience it's always ideal to have the proper tools for the job. An adjustable spanner wrench is ok, but I think it would get annoying going from the larger collar to the small collar during your adjustment process, and having to readjust the wrench each time. Just my 2 cents. Spend the $25 on the ones that Stance wants you to use.
Old Jul 26, 2011 | 03:05 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Originally Posted by sry110
This.
There's no reason to ever touch the larger collar, unless you're corner balancing the car. You're supposed to use a punch and hammer on the lower mount collar anyway. The spanner wrenches are really only for adjusting spring sag/pre-load, which like I said, you shouldn't be messing with anyway.
Old Jul 26, 2011 | 04:57 PM
sry110's Avatar
sry110
I probably misspoke. I was speaking on the basis of my coilovers (BC BR type) where you can lower the front height by:
1) loosen the smaller collar at the bottom (where the shock body threads into the lower fork member)
2) Put larger wrench on larger upper collar (directly under the spring) and turn to the left so that it threads down into the lower fork member. The entire shock body turns, but the large collar does not turn because the smaller upper collar is jammed up underneath it, so the length of the spring does not change. The piston rod (not sure that's what it's called) that goes up thru the strut tower rotates freely within the upper strut mount, allowing the shock body to rotate in this manner.
3) When desired height is reached, tighten the small lower collar to secure the shock body within the lower fork member.
Is that not correct? That's how I adjusted my BC coilovers and it seemed to work fine, but again the construction may be way different from the Stance Pro so I could be way off base.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
