Fender clearance question
Hey guys, I'm about to install a set of Stance GR+ coilovers on my 2003 Nissan 350z. I have a quick question, and I haven't been able to find anything with the search feature. I'm just curious, for the guys that are tucking tire in the front fender. How do you turn without absolutely destroying your front fender? lol If anyone could answer that for me, let me know. Thanks
I'm not going for the hellaflush look where my wheel is 25mm past my fender. My wheels/tires will be perfectly flush with my fenders with a bit of negative camber. I'm just worried if I'm tucking part of my tire in the front fender and then try to turn full lock it'll crack my fender. How do you guys do it?
You have to understand how the front tires actually turn when you turn the wheel. Set the wheels sortaflush, lower it, and try it. I can only get one finger in the gap (lol) and my concern is rubbing on the various arms underneath the car rather than the fender.
note -> I run Enkei NT03's 18x9.5 and 10.5
/thread
Really? I run RPF1 in 9.5 +15 up front with a 275/35-18 and need camber for clearance. Nothing wrong with some meat on the road. My street setup is NT03 +17 (has a spacer ) 255/40 and would slightly rub before i added extra camber.
275 is too much IMO for the fron, I dont see any reason to run a 265 at best on a 10/10.5 wheel up front. like example, rpf1 18x10.5 alll around with 265/35/18 all around. My ideal "track setup" anything else seems too excessive for road racing. maybe a 285 out back if you have FI or built.
I would Ideally opt for a 17" wheel for serious track use. But 275 for the fron is excessive, 275 is Wide as I would go in the rear, but I'd Still opt for 265/45 all around or 265/45 F 265/45 R on a 9.5 wheel width. Theres no reason to run such wide tires with a 280hp car that weighs 3k+ Besides, alot of track tires reguardless of wheel diameter run a 45 aspect ratio because of Tire roll and weight shifting dynamics it increases grip by letting the tire roll and not the car. Besides, Tires are weight too.. So reduce you're rotating mass go faster in and accelerate earlier out. Most the JDM landers run a 265/35/18 square setup as it is for their shop/track cars, But lets create our own theories against proven setups. Just because I like my car to be low and flush doesnt by any means make me less of a driver. My cars on the street, not the track. Why wear running shoes with my three piece suit?
So Japo land is the #1 authority in building fast cars? What works for them on the perfectly smooth tracks they have, may not produce the best results out here. That is the reason why anyone who cares about performance will not use alot of the GayDM suspension parts.
