350EVO swaybars with stock bushing?
Old Dec 16, 2003 | 05:06 PM
jaewonkim's Avatar
jaewonkim
Default 350EVO swaybars with stock bushing?
While I looked up the 350evo website, I noticed that the poly bushings are now optional for the sway bars. Anybody is using those sway bars with the stock bushings? Does it fit nicely or you needed some hacking?
If I go with the poly bushing, will I get noticeable perf improvement? Those bushings are ~$110.
Thanks.
Old Dec 16, 2003 | 05:44 PM
FLY BY Z's Avatar
FLY BY Z
Not worth 110 dollars but I know someone who swears by them. He'll be posting soon.
Old Dec 16, 2003 | 07:28 PM
dwnshift's Avatar
dwnshift
The polyurethane bushings are big improvement over the OEM rubber bushings. They are highly recomended for max performance. They are def worth the money. Just sold another two sets of sway bars today. We are fully comitted to providing the best performance for the customer at 350EVO.
Some new goodies are coming!!!!!
Old Dec 17, 2003 | 03:36 AM
jmark's Avatar
jmark
BJ,
When will the new poly bushings be in for the sway bars?
Old Dec 18, 2003 | 04:20 PM
little_rod's Avatar
little_rod
OK, dwnshift, explain to me the difference here. Why are the bushings better with your sways, and can you really feel the difference?? What is there benefit here?
Old Dec 28, 2003 | 12:48 PM
little_rod's Avatar
little_rod
bump for answer from dwnshift.
Old Dec 28, 2003 | 03:13 PM
dwnshift's Avatar
dwnshift
little rod.
Sorry for the delay.......
Rubber bushings are much softer than polyurethane or delrin. A softer bushing for a sway bay will have more flex or crush....the bar will move around in the bushings under load.
A stiffer bushing will keep the bar static inside the bushing and bracket allowing for quicker more effective weight transfer through the sway bars.
Yes there is a differnece and it can be felt.
Old Dec 28, 2003 | 03:18 PM
jmark's Avatar
jmark
BJ,
Have you received the redesigned poly bushings for the sways yet?
Old Dec 28, 2003 | 03:19 PM
dwnshift's Avatar
dwnshift
Will talk to them tomorrow....we have a couple other irons in the fire there also.
Old Dec 28, 2003 | 03:36 PM
FLY BY Z's Avatar
FLY BY Z
Any difference from the products Energy Suspension produces?
Old Dec 28, 2003 | 03:39 PM
dwnshift's Avatar
dwnshift
Yes.....I believe the ones that ES does fit the OEM sway bars. I am also sure that the make up or compounds are different. We work with a local company for our bushings needs.
Old Dec 28, 2003 | 03:41 PM
jmark's Avatar
jmark
Hope it is the problem rear suspension bushings.
Old Dec 28, 2003 | 03:46 PM
dwnshift's Avatar
dwnshift
I have been able to work witht the bushings we have now and open them up. The ones we will be getting will be made with a bigger diameter for the sway bars.....
The other things they are working on are a new..............for better.......and a new.........!
just have to wiat and see!
Old Jan 16, 2004 | 03:54 AM
jmark's Avatar
jmark
BJ,
Where do the new sway bar poly bushings stand? What sway bar settings are you running on your street Track with the Konis? How is the understeer? Am I correct in saying that if both ends are set at medium the stiffness in the rear will be increased and that will lessen understeer?
Old Jan 16, 2004 | 04:56 AM
John's Avatar
John
I'll let BJ comment on the status of the new bushings, as it should probably come from the horse's mouth himself (he's been a bit frustrated with it).
As for the settings, while I do not have Konis, I do run at medium settings on the street, and the car is relatively neutral. So what you are saying is in fact correct. HTH.
Old Jan 16, 2004 | 05:05 AM
jmark's Avatar
jmark
Thanks John. Are you running the poly bushings or stock with your 350Evo sways?
Old Jan 16, 2004 | 05:45 AM
350zSpeedRacer's Avatar
350zSpeedRacer
When I installed my 350EVO sways, my stock bushings showed signs of tearing. I wouldn't have wanted to put those things back on because I track my Z quite frequently and it's my opinion that those bushing just can't keep up.
My poly bushings, however, have held up quite nicely.
Old Jan 16, 2004 | 06:06 AM
John's Avatar
John
I'm running the poly bushings. When installing them, lube up the bushing with marine grease.
Old Jan 16, 2004 | 03:33 PM
staggered_IS's Avatar
staggered_IS
I've never heard of a company not including poly bushings with their aftermarket sway bar set. I've heard of poly bushings sold separately for stock sways (Daizen sport tuning).
Old Jan 16, 2004 | 03:45 PM
jmark's Avatar
jmark
You can buy 350Evo sways either with or w/o poly bushings.
