Tein basic coilovers
Old May 18, 2012 | 02:43 PM
hotdawwgman's Avatar
hotdawwgman
So I am having some issues with lowering my rear even more. i can remove the rubber stop and be ok? wouldn't the Spring pop out as soon as you lift the car????
Old May 18, 2012 | 03:45 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Do not remove the spring mount.
Old May 18, 2012 | 04:03 PM
hotdawwgman
ok, so why do some people say to do it, and some others say not to? Any who, I will just do the springmount... All these years, and I am finally gonna do it to my Basics.
Old May 19, 2012 | 11:02 AM
terrasmak's Avatar
Can't remove it, but you can shave it
Old Jun 24, 2012 | 04:15 PM
TucsonG35's Avatar
TucsonG35
so, cutting the rear spring mount .5 and removing a collar would yield an extra inch in rear drop?
thinking about purchasing the basis but the modest rear drop is pulling me back
Old Jun 24, 2012 | 06:52 PM
terrasmak's Avatar
Roughly , your car will be slammed/fucted up.
Old Jun 26, 2012 | 02:51 PM
D'sNuts's Avatar
D'sNuts
Originally Posted by Vivid Racing
I used to work for a big coilover company and I've seen almost as many coilovers with perches missing as I've seen with all the perches intact
As long as the perch is tightened against something, it's fine.
Got a link to this? The only Z's I've worked on were on coilovers. I have no experience modding OEM suspension. I've ridden in and driven Zs on lowering springs, but never installed them on the Z.
EDIT: I found the DIY. That part that is cut is actually completely removed when installing coilovers and replaced by an adjustable metal sleeve. Check the pic below, it's the gold part. You use the green collars and perches on the gold sleeve to adjust ride height.
Some coilovers use a "true coilover" aka "full coilover" in the rear, which completely bypasses the stock mounting of the spring and places the spring right on the damper, like the fronts.
What are the pros/cons of using a "true coil over" in the rear? This would allow you to eliminate the spring boot correct? Can you name off a couple of companies
Old Jul 4, 2012 | 12:59 PM
TucsonG35's Avatar
TucsonG35
the newer basis coils DO NOT require use of the rear upper mount. but the rear drop is still listed at only 1.5
Old Jul 4, 2012 | 01:45 PM
AdvanZ33's Avatar
AdvanZ33
Instructions say you do. Did you receive something different?
Old Jul 4, 2012 | 01:48 PM
AdvanZ33's Avatar
AdvanZ33
Oh you must be referring to the spring mount.
Old Mar 6, 2013 | 06:23 PM
PaqmanBluZ's Avatar
PaqmanBluZ
sorry for bumping an old thread, but does anyone have input on the ride quality of the Basis coils?
Old Oct 20, 2014 | 11:01 AM
isy_nismo's Avatar
isy_nismo
Do you know if the rear springs can fit on the titanium rear mid Links? Do u know the diameter of the springs...
Old May 5, 2016 | 08:04 AM
RichV's Avatar
RichV
Bringing up an old thread. Im looking to buy a set of Basis coilovers. Can anyone else chime in on the ride quality and if these have given anyone problems? It looks like the rear won't go super low but I only want to go about and inch or so below stock. looking for about a one finger gap or a little less. I don't want to tuck my tires. Thanks fellas
