kinetix control arms hitting inside fender
Old Nov 5, 2011 | 11:33 AM
jennkent5454's Avatar
jennkent5454
Default kinetix control arms hitting inside fender
I just put on these kinetix control arms, I went to get the allignment done and they were unable to because the knuckle is hitting the inside of the fender and they need to be adjusted out even farther. look at the pictures, does everything look ok? should I cut a notch out of there to allow it to travel more? or can I adjust the struts? whats my problem here?
Old Nov 5, 2011 | 01:20 PM
Czarrr's Avatar
Czarrr
The infamous knocking of low quality control arms
I know the feeling man.
Old Nov 5, 2011 | 08:13 PM
JDMStanced's Avatar
JDMStanced
whatever is in the way of A-arms, cut em off. Drill a big hole in the wheel well.
that's what i did.
Old Nov 5, 2011 | 08:18 PM
KingBaby's Avatar
KingBaby
Hardest Setting
A little camber won't kill you!
Old Dec 14, 2011 | 07:48 PM
JasonZ-YA's Avatar
JasonZ-YA
see here...
https://my350z.com/forum/9518469-post21.html
-J
Old Dec 14, 2011 | 07:49 PM
JasonZ-YA's Avatar
JasonZ-YA
how many threads are actually engaged into the upper arm itself here???
-J
Old Dec 14, 2011 | 11:20 PM
With respect Kinetix lost credibility about 6 years ago.
First they gave us catalytic converters that failed internally at about 30,000 miles. Then came the upper plenum that does nothing. And now, as your have found, suspension components that do not fit. Their stuff looks trick - its just terribly unreliable.
Justin100
Nov 25, 2021 06:26 AM
3vilbunny
Jul 18, 2017 05:10 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
