Negative Camber Issue
Hey guys. I just installed my new RPF1 rims and Hankook RS3 tires. When I drove to Nissan to get an allignment I noticed that I have a negative camber of 2.0 and 1.6 in the front. This is obviously too much negative for a daily driver. I have Tein-S Tech springs and Ichiba camber kit that I also just installed. I made sure to open the control arm all the way up (most positive position).
My back tires are fine and within spec. Why are my front tires so far out of spec? I was running -0.8 camber with the stock control arm, 225/45/18 and Tein S Techs. Now I'm running -2.0 with Ichiba control arm, 265/35/18 and Tein S Techs.
Is there anything I can do short of getting different control arms? What caused the camber to go so negative.....only thing I can think of are the new tires.
Thanks
Thanks
Well I don't want to be set up for track, I want to be set up for daily driver. I didn't think that tires change camber but the only thing other than tires that changed was the Ichiba camber arm.
I'd like to run around 1.0 negative camber and no more than -1.4
The Ichiba arms will only add 0.2 - 0.5 on s-techs. You need SPC arms with the shims to get back in spec. Plus, ichiba's just plain suck bawls, all 4 corners blew bushings in 5k miles normal street use for me. Notice that clank sound on bumpy cornering? Yea that's the ichibas sucking.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
