Toe bolts
Old Jan 5, 2012 | 07:05 AM
acke15's Avatar
acke15
Default Toe bolts
I'm trying to see if there are any other toe bolts besides spc. I'm running the stock spring bucket. Will only be dropped around 1-2"s. I have the spl rear camber arms. I'm going to use the spl lockout bolts on those. Just trying to see if there's another option to the spc toe bolts. Thanks
Old Jan 5, 2012 | 07:07 AM
Junkster's Avatar
Junkster
If you get rid of the spring bucket you can run toe arms...other than that i think the bolts are the only option...
SPL makes different spring buckets as well...
Old Jan 5, 2012 | 07:56 AM
Gsedan35's Avatar
Gsedan35
144k never had a camber or toe cam move one bit. Run a ton of setups and I don't slowdown for squat. For me the whole movement myth is just that, a myth.
Old Jan 5, 2012 | 08:10 AM
acke15's Avatar
acke15
Thanks for the responses. I can't justify spending 600$ for the spl midlink. So the stick bolts will be fine?
Old Jan 5, 2012 | 08:11 AM
Zach@Forged's Avatar
Zach@Forged
Vendor - Former Vendor
As Junkster stated, you could run the SPL toe arms and rid of the spring buckets - http://www.forgedperformance.com/sto...at=1851&page=1
Other than that the SPC toe bolts are really the only option to choose from - http://www.forgedperformance.com/sto...at=1851&page=1
Old Jan 5, 2012 | 08:38 AM
Gsedan35's Avatar
Gsedan35
As long as you can dial in your toe settings after you've dialed in your camber settings.
Performance alignment or not, you will want rear toe in.
Old Jan 5, 2012 | 08:49 AM
acke15's Avatar
acke15
I don't have true coilovers. Kw v3's. Im going to use my stock rear springs. So the toe arm is outta the question. Hopefully I can get the rear toe in
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
