Question about camber + springs
Old Jan 28, 2012 | 08:03 PM
Brogan07's Avatar
Brogan07
Default Question about camber + springs
Hey, was just wondering if I could get some advice from somebody with the same setup as me. Couldn't seem to find anything in search.
I have an 07 Enthusiast, stock wheels/tires with 25mm spacers x4. I just purchased a new set of Eibach Pro Kit springs (1", 1") from a member, and was wondering whether or not I will need any additional camber/toe adjusting once lowered. Thanks.
Old Jan 28, 2012 | 08:10 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Not necessarily! As long as your alignment is straight!
Old Jan 28, 2012 | 08:45 PM
Brogan07's Avatar
Brogan07
And that's something I will find out when it's done, correct?
Old Jan 28, 2012 | 08:54 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Yes sir you install your springs and get an alignment at a reputable shop. They should then try to get it in OEM spec the closer the better it is on tire wear.
Old Jan 28, 2012 | 09:12 PM
Brogan07's Avatar
Brogan07
TY sir.
Old Jan 28, 2012 | 10:29 PM
Don't know. Install the springs. Have alignment checked.
Old Jan 29, 2012 | 06:55 AM
Deteria's Avatar
Deteria
I believe you will need camber adjustments if you are trying to get within factory specs.
I am dropped on Tein S-Techs (-.7" F -.6" R). My Rears are good within specs. Front's are @ -1.6 to -1.8 deg camber. Slightly on / over the recommended specs. However, I have a friend that used to be dropped on GF210s and his was much lower than mine. He ran -4 deg camber, but said it's fine and never bothered to get camber arms.
Old Jan 29, 2012 | 09:15 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
only way to know is install the springs, put the car on the alignment rack, and check the specs. Factory rear adjustment is very slight, might be enough, might not be
factory front adjustment only accounts for toe, no camber adjustment is possible with stock components.
issyz
Jul 2, 2017 03:04 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
