Lowest spring?
Old Feb 6, 2012 | 08:32 PM
TwoFastFurYa's Avatar
TwoFastFurYa
Default Lowest spring?
Who makes the lowest spring for the Z? I believe it's either Eibach Sportline or GF210's? Correct me if I'm wrong?!
Old Feb 6, 2012 | 09:26 PM
You are one hundred percent correct.
Old Feb 6, 2012 | 10:13 PM
TwoFastFurYa
Sportline is the lowest before getting into coilovers correct?
Old Feb 6, 2012 | 10:32 PM
OkashiZ's Avatar
OkashiZ
^ yes
Old Feb 7, 2012 | 08:11 AM
Gsedan35's Avatar
Gsedan35
Technically the lowest is Sprint at 1.75"/1.75"
IMO, if you have to go that low, your better off with a coilover system so you can hopefully actually have some shock travel. For that reason I've never included the spring in any of the aftermarket suspension lists I publish
Some other choices mentioned and not mentioned.
H&R sport progressive springs 350Z 1.3”/1” drop
Spring rates in LBS 370/400 (peak rates only, softer initial rates are unknown)
Eibach 350Z sportline progressive springs 1.2"/1.2"
F: 239/400 R: 257/435
Tanabe GF210 Series 350Z progressive springs 1”/1.2”
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown)
Kg/mm DRacing progressive springs 1.2”/1.2”
Spring rates in LBS initial/final front 252/454 initial/final rear 252/482 rear
^too much for oem shocks, Tokico D-spec would be fine
Swift 350Z Spec-R progressive springs 1.2”/1”
Spring rates in LBS initial/final Front: 291/392 Rear: 280/448
Old Feb 7, 2012 | 10:01 AM
2008_hrthree50z's Avatar
2008_hrthree50z
get sportlines and do the spring mount mod.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
