View Poll Results: is it ok to hi temp paint the rusty part of the rotor that the pads don't t
can safely paint
81.82%
you are an idiot don't do it
18.18%
Multiple Choice Poll. Voters: 22. You may not vote on this poll
rusty 350z rotors painted black
Old Feb 19, 2012 | 12:24 PM
BRIANZ1's Avatar
BRIANZ1
Default rusty 350z rotors painted black
I used barbeque paint on my rotors looks much better than beforeAttachment 331992after rusty 350z rotors painted black-brianz1-012.jpg try it if you have stock rotors just spray over rust
Old Feb 19, 2012 | 12:27 PM
350ZTheStandard's Avatar
350ZTheStandard
Amazing, just simply amazing. Did you at least sand off the rust before painting???
Amazing, just simply amazing, beauty eh
Old Feb 19, 2012 | 12:29 PM
Ruthless18x's Avatar
Ruthless18x
Wait. You painted your rotars or rotors? Because that would be dangerous and stupid.
Old Feb 19, 2012 | 12:32 PM
BRIANZ1's Avatar
BRIANZ1
this paint is good for rust and i just cleaned them first and i only painted the part away from the pads touch. There is a ridge that i painted on. The new 370z do this now i just copied them
Old Feb 19, 2012 | 02:19 PM
derekinthez's Avatar
derekinthez
Doh!
Old Feb 19, 2012 | 02:35 PM
FacePalm717's Avatar
FacePalm717
Oh em Gee
Old Feb 19, 2012 | 03:01 PM
Waiz's Avatar
Waiz
Wait, did you actually put paint on the rotor surface?
Old Feb 19, 2012 | 03:05 PM
KornerCarver's Avatar
KornerCarver
If the rotor surface was painted, the paint would be removed with the first application of the brakes. It would not be a big deal.
Old Feb 19, 2012 | 03:35 PM
I did a thread some time ago about painting new brake rotors. Helps prevent corrosion.
Old Feb 19, 2012 | 03:41 PM
BRIANZ1's Avatar
BRIANZ1
wow so nice im doing the front next before i put them on just like that
Old Feb 19, 2012 | 04:03 PM
2TH PWR's Avatar
2TH PWR
I gotta be honest.
I did something like this too. Sanded the hub and masked off the rotors with tape and a cardboard cutout.
Then I used high temp header paint....
Old Feb 19, 2012 | 04:54 PM
SirSpeedyZ's Avatar
SirSpeedyZ
Why not just get zinc plated rotors to start with? My rotors don't have rust at all
Old Feb 19, 2012 | 05:44 PM
jv350z's Avatar
jv350z
ding-ding-ding!
Old Feb 19, 2012 | 06:05 PM
dkmesa350z's Avatar
dkmesa350z
Great solution! Rather than pay $10 to coat a set of perfectly functional rotors, just pay $500 for a new set :high five!:
Old Feb 28, 2012 | 08:08 PM
4DRVIPER's Avatar
4DRVIPER
You could always just have the hub powder coated. Would last ALOT longer than paint, even the hi-temp paint.
Old Mar 1, 2012 | 12:04 AM
BRIANZ1's Avatar
BRIANZ1
the price of powder coating is expensive even for small things. hope it last a while
Old Mar 1, 2012 | 12:54 AM
L-Fab's Avatar
L-Fab
Not always but I wouldn't recommend powder so much as I would high temp paint.. also there's no issues behind painting the rotors.. the pads will remove any over spray from the rotors themselves.. we've actually sand blasted rust off and painted a few sets already.. looks much better than a conventional zinc coating
Old Mar 2, 2012 | 05:29 AM
4DRVIPER's Avatar
4DRVIPER
This is not always true. I powder coat items for members of several forums I am a member of. I guess its who you know. Some shops can be expensive, but its still worth it as far as durability. Most of the cost with powder coating is prepping/CLEANING the part to be coated. I remove ALL rust/paint/oil/grime/etc. down to bare metal, clean with acetone, then pre heat part to out gas any contaminants, clean the newly surfaced out gassed contaminates, and finally coat the part. If you are worried about cost, simply have more small items coated the same color at the same time. Cost waaay less that way because your not changing powders and risking cross contamination, and the time to coat multiple items isnt much more than 1 item.
Old Mar 3, 2012 | 05:30 PM
L-Fab's Avatar
L-Fab
^ +1 we do our own powder coating and prep is definitely the most time consuming part.. spraying is fairly simple so long as only a single color is involved
Old Mar 3, 2012 | 06:35 PM
FATPUBUS's Avatar
FATPUBUS
i did that 2 years ago and mine still are fine. no rust, no peeling or flaky paint either.
