03 350 Kinetix Front Upper Camber Kits????
Old Mar 9, 2012 | 07:19 AM
Dr. Venture's Avatar
Dr. Venture
Default 03 350 Kinetix Front Upper Camber Kits????
I just purchased this kit and i am realizing that although the set up is good, that the design of the adjustments is not as good as i thought it to have been.
does anyone have this set up?
I see that the ball joint section that screws into the control arm only has a locking nut. But does not have an adjusting nut to be able to turn the adjustment in and out of the control arm.
It seems as if every time i have to do an alignment i would have to remove my rims, and split the upper joint away from my spindle in order to spin on or off the adjusting screw in order to make the adjustment. SEEMS LIKE A HELL OF A LOT OF WORK to do for an otherwise simple alignment!!!!
Anyone else have this kit and have this same issue?
here is a link to the product.
http://www.hopupracing.com/kifracaad35g.html
Old Mar 9, 2012 | 08:51 AM
Dr. Venture
FORGET IT!!!
after putting them on i realized that there is enough room if i lif the vehicle to take off the joint with out removing the tire. STILL is a lil pain in the butt, but hey its stronger than a slider style.
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
samansharif
Sep 25, 2015 12:31 PM
