2006 rear caliper bracket (for 2003 upgrade) pic/part number
Searching all over the this forum, the net, and assembly drawings and I can not figure out what bracket I need to source to allow me to fit the larger rear rotors on the 2006+. I need new brakes, so I want to do this upgrade at the same time (i have the fronts upgraded already to 2006).
I need a picture of the bracket it self so I know what I'm trying to source online and/or in a junk yard. If you really want to make it easy on me, a part number for the bracket would be good to. I can't find it in any drawings on any of the nissan parts sites.
I've read all the upgrade threads about this, none list a part number or have a specific picture of the bracket that I can find.
Can anyone help?
Can anyone help?
the bracket for the rear caliper is part of the whole assembly itself. the diagram you posted seems to not have it at all.
http://www.courtesyparts.com/350z-pa...5_806_808.html
this shows the brackets but not as a separate piece. if you got 2006 rear calipers you should already have the bracket.
I have '03 calipers now. I will either buy the bracket or the '06 calipers. If I can buy any set of '06 calipers and it will be attached then I will go get some from napa and turn mine in as cores (or ebay them). I'm just worried that the bracket I need stays attached to the car and not the caliper...
Can anyone help?
Can anyone help?
Here is the Left from RockAuto with Centric PN..it's $81 Total ($50 core charge refund, but you don't have a core to return).
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
