g37s rear swaybar on a Z!!!
Old Jun 21, 2012 | 01:44 PM
Cide's Avatar
Cide
Default g37s rear swaybar on a Z!!!
Hello. A few weeks back I got a whole set of swaybars from a g37s and seeing how similar the rear suspension is to the 350z i decided to see if it worked. After doing some measurements i saw that the g37 sway is 26mm compared to the 21mm z sway. So I put up the car took the stock one off and went ahead with the swap. After mock up everything looked like it would line up. There was one issue. The mounting bracket has the holes 2 far apart. After slight porting of the wholes it slipped in fine. Been a couple of weeks now and there have been no noise or anything weird. Sorry i have no pics of the install but i will post some soon since this seems to be a new alternative to buying aftermarket swaybars. Well the rear at least.
ps. it will not work if you have aftermarket true dual exhaust as the sway bar has a loop on the pass side for the factory g37 exhaust.
Stevo Z
Oct 3, 2015 09:14 PM
