Megan street coilovers
Old Aug 14, 2012 | 06:22 PM
Highstar's Avatar
Highstar
Default Megan street coilovers
Recently installed megan streets on my G35, and i maxed out the front and it isnt as low as i would like, anyone know any ways to get it lower, i know i can drop the spring but i dont want to mess up the spring load.
Old Aug 14, 2012 | 06:26 PM
terrasmak's Avatar
Set the preload to 0
Old Aug 15, 2012 | 04:10 PM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
There are a couple different ways, including lowering the springs down. I typically wouldn't recommend this method though.
Pretty sure if you used different springs (possibly shorter) that it would lower more.
Old Aug 16, 2012 | 10:35 PM
Highstar's Avatar
Highstar
how is that done?? I installed the coils directly out of the box, the springs had no movement so im guessing the preload was set from factory.
Old Aug 17, 2012 | 12:43 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Start over!
Installed right out of the box? No adjustments? Of course it's not going to be low...
Put it back on jacks and adjust the right way....
Don't mess with the preload! Just the height adjustments!
After you SEARCH how to do so!
Old Aug 17, 2012 | 01:59 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Megan actually has some of the most informative coilover adjustment pages. Preload isn't as scary as some people thing, check them out:
http://www.meganracing.com/tech/inst...l%20coil-overs
http://www.meganracing.com/tech/inst...ing%20pre-load
Old Aug 17, 2012 | 10:49 PM
Highstar's Avatar
Highstar
Originally Posted by KingBaby
Start over!
Well of course i adjusted the height. I didnt mess with the preload, I did move the lower mount of the coilover(adjustment) all the way up there for maxing it out. I think I stated that I maxed out the coils but its not as low as I was hoping for.
Stevo Z
Oct 3, 2015 09:14 PM
