Coilover suggestions?
Old Sep 7, 2012 | 10:42 AM
jhowald93's Avatar
jhowald93
Default Coilover suggestions?
Alright guys, I have a 06 350z that I dropped a few inches in the rear with a cheaper coilover setup ( couldn't get the front 2 on because of stubborn strut bar screws), and even on the softest setting, I was bumping up and down local/highway roads like a fat kid riding a bike made of wood. <---
But anyway, I was thinking about buying a better setup. I have a few brands in mind. HKS RS sounds like a good setup from what I've read. Im just wondering if there is anyone out there that has a good setup with a some what comfortable spring rate?
Old Sep 7, 2012 | 11:31 AM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
What's your budget and what will you be doing with the car?
Old Sep 7, 2012 | 11:49 AM
jhowald93's Avatar
jhowald93
Anything less than 2k. And just a daily driver
Old Sep 7, 2012 | 12:13 PM
terrasmak's Avatar
Originally Posted by jhowald93
I dropped a few inches in the rear.
Here are you 2 big problems. Few inches is 3 to 4 , so you put it on the ground and it rides like ***. You have no suspension travel , and will not have suspension travel with that much of a drop.
Old Sep 7, 2012 | 03:10 PM
ModBargains's Avatar
ModBargains
If it's just for daily. You should look into KW Variant 2 . It's has best material construction quality of any coilover kit that i've seen. It also has life time warranty on their coilovers! Price is well under you budget. it's also height adjustable and adjustable rebound damping. it's perfect for daily drive!
Old Sep 7, 2012 | 04:03 PM
VMRWheels's Avatar
VMRWheels
+1 for KWs.
Heard pretty good things about Stance coilovers as well. I'd probably go with KWs before Stance though.
Old Sep 12, 2012 | 03:58 AM
maXmood's Avatar
maXmood
Under Boost!
I need something for the streets also, my Tanabe GF210 wore out @ the rear.. can i buy a rear set of coilovers only?
Old Sep 12, 2012 | 04:38 AM
angelo350z's Avatar
angelo350z
I bought a set of KW V2s, got them installed, but never had the chance to drive my car since I'm in a different country. The people who worked my car (German shop with actual Nissan race cars) had nothing bad to say about the setup, though they only tested my car on smaller tracks and not the Nurburgring. Anyway, I did my research before my purchase so I'm confident they'll do quite well.
Old Sep 16, 2012 | 11:15 AM
35028's Avatar
35028
I run stance coilovers, and its probably the same for other coilsovers, but ride height does not affect suspension travel... Stance coilovers come with separate adjustable lower bracket which allows the dampers to retain its full stroke even when lowering the vehicle.
Old Sep 16, 2012 | 11:19 AM
end of z world's Avatar
end of z world
I'm in the same boat and I've learned that for a happy medium of lowering dd comfort and trackabity, kw v2 or v3 is where its at. That's the path I'm taking
Old Sep 16, 2012 | 11:31 AM
terrasmak's Avatar
So you are saying that you can lay the body on the ground and still have full travel ? Does your hood and fender move out of the way for the tire to move as your driving , how about your upper control arm ? What is the point of having 2 inches of up travel (if you can get that much ) if your chassis touches the ground after 1 inch.
YOU ACTUALLY HAVE TO THINK, you have a rear car, real physics are applied , it's not like a video game.
Old Sep 16, 2012 | 11:24 PM
freddys 350z's Avatar
freddys 350z
also, please change your front coilovers. a shop should be able to take those screws out for you cheap if your incapable of doing so.
did you try stiffening them up? if the setting is too soft it wont be able to properly dampen the spring, making it bouncy. maybe you can describe how it drives better. it would be easier to help.
Old Sep 17, 2012 | 01:25 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Made no sense...
If 2k is your budget you have a few choices of quality brands to look at!
Search Op search!
Old Sep 17, 2012 | 01:55 AM
350Zdj's Avatar
350Zdj
Happy kW v2 user here. Good for daily driving and it works even better when you take on some twisty roads.
more info on other coilovers here:
https://my350z.com/forum/brakes-and-...d-reviews.html
Old Sep 19, 2012 | 08:46 PM
ModBargains
so far i have nothing but happy customers with the KW coilovers
ablaine
Nov 29, 2016 10:13 AM
