breaking loose coilover collar
Old Dec 29, 2012 | 09:31 AM
yellowxhoodie's Avatar
yellowxhoodie
As everyone else already said,
PB Blaster
Heat
Screwdriver and rubber mallet
Old Dec 29, 2012 | 10:54 AM
JDMStanced's Avatar
JDMStanced
actually heating up the collar sounds like a good idea.
i have a heat gun. would it be fine to heat up the collar and everything around it, like the bottom shock and the strut w threads?
i dont think i can be so accurate that i can only heat up the collar.
Old Dec 29, 2012 | 11:32 AM
yellowxhoodie
No, dont use a heat gun, Use an actual torch and heat up all around the collar. Keep the flame away from the bottom mount.
Old Dec 29, 2012 | 03:26 PM
JDMStanced's Avatar
JDMStanced
then the coilover needs to be off the car. its going to be a PItA to break it loose when its off the car. even its mounted on the vice.
i have a feeling the bottom piece is going to bend or something if vice is used
Old Dec 30, 2012 | 02:03 PM
terrasmak's Avatar
I would think twice before I used a torch on a High Pressure gas strut
Old Dec 30, 2012 | 03:18 PM
freddys 350z's Avatar
freddys 350z
it should only take about 10-20 seconds of heating the collar. as long as you dont focus the heat on the body it should be fine.
Old Dec 30, 2012 | 06:55 PM
pro_350z's Avatar
pro_350z
Just hit it with your purse
Old Dec 30, 2012 | 07:04 PM
terrasmak's Avatar
Aluminum heats up how fast
Old Dec 30, 2012 | 09:52 PM
freddys 350z
very fast...the body should be steel or stainless. if your afraid of heat dont use it, but its a very useful tool for stubborn nuts, bolts etc.
wanderingstuden
Jan 28, 2016 07:03 PM
