breaking loose coilover collar
Old Dec 27, 2012 | 03:53 PM
JDMStanced's Avatar
JDMStanced
Default breaking loose coilover collar
hi, i tried breaking loose the front coilover collar, not the ones to change the preload, but it's like stuck on there.. soaked with WD40 before trying.
Tried to break it loose with the hook (?) like tool (the tool that comes with the coilover) that is extended with a pipe.
This didn't work either. Hammering the end of the tool didn't work either.
The edges of the collar is kinda rounding off now..
How do you guys go about breaking it loose?
i have stance gr+
Old Dec 27, 2012 | 04:20 PM
SlowNFurious's Avatar
SlowNFurious
Have you removed the coilover from your car or are you working with it while on the car? Also, do you have 2 of the hook shaped adjustment tools?
Old Dec 27, 2012 | 04:27 PM
JDMStanced's Avatar
JDMStanced
the coilover is still on the car. i do have the two hook shaped tool.
the edge of these rounded off too..
Old Dec 27, 2012 | 04:36 PM
SlowNFurious
Well I don't need to tell you that you fawked up. Take the coilover off the car, it will be much easier to work with. If the adjustment tools are still able to get hooked on the collars than try using a pipe on both tools. Lay the coilover on the ground and put your foot on it while pushing down toward the ground on both pipes.
If there is no way to get the tools to hook to the lock collar, than you will need to lock the lower seat in a vice and use a hammer and screwdriver to bang the collar loose.
Otherwise its time to bust out the cutting wheel and cut it off. Be careful not to damage the threads.
Old Dec 27, 2012 | 04:45 PM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
Tried and true method of breaking seized collars loose is a flathead screwdriver and a rubber mallet. Just don't go too crazy when you start trying to hammer them loose. I've also heard good things about PB Blaster.
Old Dec 27, 2012 | 05:32 PM
DHawley's Avatar
DHawley
This.
The "hook like tool" is called a spanner wrench btw.
Old Dec 27, 2012 | 06:22 PM
Mcutali's Avatar
Mcutali
Red face coilovers
I think you've done pretty much what should of loosened them up.
I have Bc Racing Br type, and after a year..they were a b tch to get loose.
Only thing different I used PB blaster and it took some muscle, and smash the hands a few times for good measure. Let em soak for awhile and get a strong friend aha.
Old Dec 27, 2012 | 07:36 PM
lotteman's Avatar
lotteman
i hope you know that one of the collars is reverse threaded too...
Old Dec 28, 2012 | 01:04 AM
JDMStanced's Avatar
JDMStanced
Although i tried, spanner wrench + hammer, i'll try the pb blaster and flat head+ hammer while the coilover is on the car.
i'm trying to loosen the front right side. Which way should the collar be turned? the one for adjusting the height, that is touching the bottom shock.
Old Dec 28, 2012 | 07:08 AM
SlowNFurious
Are you certain about this?
Old Dec 28, 2012 | 07:22 AM
DHawley's Avatar
DHawley
There are no reversed threads. At least I've never seen coilovers with them anyway and find the idea of them a bit odd.
Old Dec 28, 2012 | 08:10 AM
terrasmak's Avatar
Aerokroil works great , I clean my thread every coiple months to keep them nice.
Old Dec 28, 2012 | 08:42 AM
User 42426's Avatar
User 42426
If you are looking over the collar, you should be turning it counter clockwise. Use the flathead/hammer method. Its odd that you tried all those things and its still stuck..
Old Dec 28, 2012 | 09:45 AM
VMRWheels's Avatar
VMRWheels
+1
Not aware of any reverse threads on coilovers.
Old Dec 28, 2012 | 09:52 AM
herrschaft's Avatar
herrschaft
Tanabe Sustec Pro-5 coilovers. When they came out of the box, both collars turned in opposite directions, making it appear as if one was reverse threaded. Maybe they just installed one on each strut upside down for no reason, who knows.
Old Dec 28, 2012 | 03:39 PM
JDMStanced's Avatar
JDMStanced
then i turning counter clockwise...
Old Dec 29, 2012 | 12:16 AM
lotteman's Avatar
lotteman
sorry.. i think i might have been a little tired and remembered that you have to lock the collars together by tightening them against each other. Confused myself haha sorry again.
Old Dec 29, 2012 | 03:30 AM
freddys 350z's Avatar
freddys 350z
if you cant get it loose with the hammer and flathead method, i would suggest putting a little heat on the locking collar, then use the hammer/flathead method. i use a propane torch i bought at home depot. a real helpful tool for the DIYer
Old Dec 29, 2012 | 04:38 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
op would it kill you to post a picture?
Old Dec 29, 2012 | 05:44 AM
MR RIZK's Avatar
MR RIZK
my 2c
1. Thread lock was used when installed
2. When installed the collar was tightened so tight that the threads on the collar deformed
3. You are tightening vs loosing
if the strut is out of the car you should be able to hold the larger collar with the C spanner with one foot and use the other C spanner and a rubber mallet on the smaller one. Undoing the smaller one should be easier than the larger one which has pressure from the spring.
Potentially try this:
