???? On stance GR+ Coils when car is jacked up
Old Feb 7, 2013 | 06:59 PM
Lexo350z's Avatar
Lexo350z
Default ???? On stance GR+ Coils when car is jacked up
Ok so I lowered the car already, we'll I think too low, I couldn't move the F en car after I put it down on the ground so I jacked it back up so I can adjust the ride height on it, but my question is this is this supposed to be like this even on jacks, cause usually doesn't the suspension hang down? Please if someone could answer I would really appreciate it. Thank you guys.
Old Feb 7, 2013 | 07:04 PM
Bmurray350z's Avatar
Bmurray350z
lol wtf
Old Feb 7, 2013 | 07:25 PM
Lexo350z's Avatar
Lexo350z
lol wtf
It's a lil funny but not the kind of answer I'm looking for. Do I have to raise it so when it's jacked like this the suspension drops but when on t.he ground that's when it compresses??? A lil help would be great
Old Feb 7, 2013 | 07:39 PM
Lexo350z's Avatar
Lexo350z
Ok so I removed the front rim just right now and here's the pick of the coils. Is there anything wrong here???
Old Feb 7, 2013 | 08:25 PM
cnz's Avatar
cnz
No man they're fine, just raise it a little... stiffer set up less shock body movement when jacked up..
Old Feb 8, 2013 | 05:30 AM
JGYMotorsports's Avatar
JGYMotorsports
Vendor - Former Vendor
stiff suspension=less suspension travel
Old Feb 17, 2013 | 01:33 PM
tidyjin's Avatar
tidyjin
I have the similar problems with the Stance, I also need to raise it but still no answers~~
wish you good luck and I will follow this thread
Old Feb 18, 2013 | 10:14 AM
JDMStanced's Avatar
JDMStanced
i have the same coilover. with 14 dampening front, the wheels drop down way more than that ..
Old Feb 18, 2013 | 10:00 PM
stascom's Avatar
stascom
I can only imagine the luxurious ride that car provides, especially with those stretched tires.
Old Mar 4, 2013 | 09:05 AM
BIGPOPPAPUMP's Avatar
BIGPOPPAPUMP
I have stance pro comps & they have settled. I'm tucked in the front & where I want in the back. Now they need to be stiffer as they've softened in 500 miles. How do I calculate the adjustment. Is one turn of the internal hex 100lbs?? I know to just move the ride height & not mess with the springs. I want to stiffen the internals of the shock in the coil over using a bondis tool (round hex). what is the turn in degrees to the lbs or kg's? Anyone? I want to be very specific with before it's aligned cuz no one drives my car but me. Alignment guy is going to have to do right. Clock wheel to center & use specs shouldn't be too much to ask for someone "certified". No one test drives my priceless Z.
Chris350z03
Oct 8, 2023 07:19 PM
etkms
Jun 19, 2022 06:30 PM
SonnyWu
Nov 24, 2015 08:19 PM
