Suspension/Springs HELP NEEDED
Old Mar 6, 2013 | 09:06 PM
Esser's Avatar
Esser
I'm running the same tire sizes as you askarya, and I'm lowered on tanabe gf210. Eibach sportlines go even lower than mine, so i do not recommend doing the spring mount mod at all. It will look perfect with your size tires and with those offsets without it.
Here is mine with 275/35/18 and 245/40/18 on gf210 with no spring mount mod:
Old Mar 7, 2013 | 05:37 AM
Bmurray350z's Avatar
Bmurray350z
thats weird because im on tanabe gf210, and even with a taller tire on mine (275/40/18) AND the rear spring mount mod done, i do not like the little gap that is there. esser, me and you have very similar wheel specs if not, the exact same. 18x10.5 +15
this picture you can see the gap im talking about
Old Mar 7, 2013 | 08:13 AM
Esser's Avatar
Esser
Could be the camber? I'm running about -2 in the rear. But you gotta remember it has to do with how much gas is in the tank at the time too lol. The drop will vary for everyone depending on how "settled" the springs are.
Old Mar 7, 2013 | 08:26 AM
Bmurray350z
these springs are definitely settled. and im running about -1.2 rear camber. shouldnt there be less gap if the tire is standing up more as well?
Old Mar 7, 2013 | 11:28 AM
askarya94's Avatar
askarya94
Ok thanks for you guys help. What about camber is that all I need in the picture I posted earlier?
Old Mar 7, 2013 | 11:32 AM
askarya94's Avatar
askarya94
Also if I wanted some lip sticking out of my tires would I have to run a smaller tire size? Maybe move my 245/40 in the back and get like 215/225 in the front? I want a little less lip than the following picture.
Attached Thumbnails Suspension/Springs HELP NEEDED-image.jpg
Old Mar 7, 2013 | 04:53 PM
Esser's Avatar
Esser
Well the first pic you posted is a completely different setup than the tire poke picture. I give up
Old Mar 7, 2013 | 06:47 PM
askarya94's Avatar
askarya94
No I got it, thanks for all the info though, it really helped me out. I just need to run 245/40 in the back with 225/40 in the front to get the stance that guy has but also have lip poking out.
Old Mar 7, 2013 | 07:24 PM
Bmurray350z
on springs, with those tire sizes ^
you will have a lot of gap
Old Mar 13, 2013 | 04:57 PM
xiaolinmonk's Avatar
xiaolinmonk
You should just save up for some true set up BC racing BR coil overs if you are looking for that kind of stance and drop in the Original Pic. They run about a grand + shipping, but usually the vendors in here could probably set you up with a discount. Also I probably seen your car around as well lol.
sherm
Apr 11, 2020 05:21 PM
