ABS Braking problem in cold weather-help!
Old Mar 14, 2013 | 04:55 AM
GothamZ's Avatar
GothamZ
Default ABS Braking problem in cold weather-help!
First off, ive searched, and found a few little things about the ABS acting up, some people say change brakes, ABS sensor, etc. However I didnt find anything about the ABS acting up ONLY during cold weather.
My issue-
Once the weather drops below around 45 degrees or so, when I step on the brakes I can feel what im guessing is the ABS acting up. Makes an awful noise and jerks/hesitates while on the brakes. NO lights, nothing comes up on the dash, simply just the ABS is engaging bad. I felt at first maybe it was a sensor, but figured if that was the case it would do this no matter how cold it is. Just looking for a solution to this issue because its annoy and feels dangerous driving the Z when its cold out, which is most of the time in WV until april/may. FYI, its an 05 touring.
Any input is appriciated.
Thanks
Old Mar 14, 2013 | 05:27 AM
JBop350's Avatar
JBop350
what kind of noise is it making?
Old Mar 14, 2013 | 11:08 AM
GothamZ's Avatar
GothamZ
kinda hard to explain, its like a grinding type noise. It just sounds like the ABS is engaging when im on the brakes in the cold. Its a hesitating grinding noise when on the brakes.
Old Mar 14, 2013 | 11:19 AM
GothamZ's Avatar
GothamZ
It could also be referred to as a clunking noise, or as ive seen before kinda of like a guitar string breaking. Maybe just need to clean the sensors? any help is appreciated.
Uriyo_
Sep 8, 2021 08:46 AM
