350Z Sway Bar & Brake Questions
Old username was Wakatow13 but I couldn't seem to access it no matter what I did. Anyway, I'm currently deployed so I'm pulling in some extra money and about to begin building my 05 base model Z. I'm getting a set of BC coilovers next week and had a couple questions. I'll be getting sway bars as well and was wondering what sway bars went well with BC suspension. I was also looking at a Stoptech big brake kit but they're pricey, what would I need to swap the OEM Brembos onto my Z?
Forget Stoptech, save the money and get OEM brembo. Then spend the saved money on some quality coilovers. KW V2 would be a great coilover to look at. Mosr sways work great. Hotchkis or motordyne would be my pick.
You fail ^ OEM Brembos are a very solid choice especially with upgraded rotors/pads/ss lines.
No need to throw thousands at a BBK unless you're a hardcore track driver or just want to blow the dough on the look
I sold my brembo setup and bought a front Stop-Tech kit, I have put 20k miles on it and maybe 4 hours of track use working good so far.
I fail because brembo brakes were insufficient for my track use? Yeah I don't follow you on that one. Maybe you fail for putting so much faith in street brakes.
You would lose money on that bet.
http://www.z1motorsports.com/350_g35...oducts_id=5373
I still have a half used set of pads if you want to buy them, LOL!
Edit- I also flushed brake fluid to MOTUL RBF600.
You seem to think that I don't know what I'm talking about just because I'm new...
From the description of XP8, it is an excellent front brake pad for car weighing less than 2,400lbs.. For the Z to be weighing 3,000~3,600lbs.. iunnos did you happen to reduce 600lbs~ or something?
