Question on Stance rear setup..
Old Apr 13, 2013 | 04:03 PM
Kipper_15's Avatar
Kipper_15
Default Question on Stance rear setup..
Hey was just wondering what has to be done when installing the the rear's? Got the front's done but a little hazy on the rear install. Got SPC rear camber kit and toe bolts. I seen the stickied toe bolt thread but just looking for some input for an easier install on anything I should know/be concerned about.
Question: Do you take out the spring that is already mounted? (Noob question I know..)
Old Apr 18, 2013 | 11:38 AM
QTB's Avatar
QTB
Assuming you have the true coilover type, yes you remove the spring after you remove the shock. The new coilover will replace the shock. Be sure to properly unload the spring otherwise it can get dangerous.
Hope that helps.
Old Apr 18, 2013 | 02:28 PM
X.et's Avatar
X.et
Don't forget to elongate the toe bolt hole so you can actually adjust the toe more than oem.
Old Apr 18, 2013 | 03:12 PM
Phenom's Avatar
Phenom
Toasty
Is the toe bolt hole a legit hole or is it a slot from the factory? In other words if you don't elongate it can the toe bolt slide around?
Old Apr 19, 2013 | 12:05 PM
QTB's Avatar
QTB
Should be a slot.
416blueZ
Jun 11, 2024 10:56 AM
bcoffee20
Nov 19, 2015 06:39 PM
PLAYDIRTY
Oct 12, 2015 07:45 AM
