No Brake Pressure after Bremdo Upgrade
Old Apr 16, 2013 | 11:07 AM
robsilver350's Avatar
robsilver350
Default No Brake Pressure after Bremdo Upgrade
I just upgraded my '03 Touring brake system to the Brembo calipers and rotors along with SS Lines. I bled the system through with my Motive power bleeder like normal. Got all the air out, tightened down all the lines, no leaks, but still have very little pressure. Pretty much no pressure apart from the pedal returning instead of sticking to the floor. Master cylinder never went empty. Wondering if I should bleed again or replace the master cylinder. Thoughts/ideas?
Driving around using just your e-brake can be a little scary at times
Edit: I'm using RBF 600 fluid
Old Apr 16, 2013 | 12:33 PM
350z006's Avatar
350z006
Maybe your master/slave cylinder going bad?
Old Apr 16, 2013 | 01:04 PM
thekinn's Avatar
thekinn
How many times did you bleed them out? just once after the install with the Motiv bleeder? I'd give it one more try and tap the calipers with a rubber mallet as you are bleeding them.
Sometimes at least one cycle the old fashion way (pumping the pedal) helps after disconnecting lines, etc.. or going through two cycles one before and one after driving the car around some and actually using the brake pedal.
Old Apr 16, 2013 | 01:20 PM
robsilver350
I'll give it a try tonight after work. Just got some more RBF in the mail today. Is it wise to recycle new brake fluid (knowing that you ran enough new fluid through that there's no more old in the lines)? Would hate to waste this stuff at $20/bottle. If a second bleeding doesn't work, I'll look into the master and slave cylinder. I just want to play with my new toys
Old Apr 16, 2013 | 01:36 PM
K51's Avatar
K51
Slave cylinder? - nothing to do with the brakes. The calipers are installed on their correct sides, right? In other words, the bleeders are at the top.
Old Apr 16, 2013 | 01:40 PM
robsilver350
Thanks for the heads up on the slave cylinder. I did not know that. Calipers are installed correctly (almost made that mistake at the beginning of the install). I also read that I should check the master for air below the reservoir? Doing everything I can on my own before taking it over to the shop with my tail between my legs.
Old Apr 16, 2013 | 04:49 PM
terrasmak's Avatar
I reuse fluid all the time, once it is clean and just trying to get bubbles out. Pain in the *** to get air out of the ABS/stability control unit without a pressure bleeder.
Old Apr 17, 2013 | 05:56 AM
robsilver350
Update: Got a ton of air out of the front calipers by using a rubber mallet on them while bleeding. I was amazed at how much air was trapped inside the caliper. Took it for a spin, had full pressure, bled it again, got a couple more bubbles, now they are solid as a rock. Than you all for your suggestions and help.
Old Apr 17, 2013 | 07:03 AM
thekinn's Avatar
thekinn
That's great news. no problem - enjoy!
Old Apr 19, 2013 | 07:17 AM
swat518's Avatar
swat518
I want to borrow your thread if op doesn’t mind. I installed an used stoptech ST40 few wks ago with ss line and HP+ pads. Used Motive power bleeder as well and bed in the pads. The brake paddle felt softer than stock when I hit it half way down, but it does have gentle brake, after I hit the paddle harder and deeper, it bites really well. So is it normal for Stoptech BBK have soft paddle feeling at the beginning or it might have air in the caliper? I rebuilt the caliper, so there is no fluid inside, I bled it in upright position followed by the instruction but I recall I only tapped 3 times on the driver side and none at passenger side.
Edit:bled again, very few air bubbles, now feel firm
