Camber Help
Old Apr 18, 2013 | 08:01 PM
Gadgetgirl's Avatar
Gadgetgirl
Default Camber Help
I just had new tires put on and an alignment today. I was told I need an adjustable camber kit. Can anyone suggest one for me. Included is my before and after measurements.
Thanks!
Old Apr 18, 2013 | 08:17 PM
ajpm26's Avatar
ajpm26
Being an alignment tech I really wouldn't worry about that being out a tiny bit, it's borderline out of factory spec.
If you really wanted to fix that you can do a quick search and checkout the different kits, spl being many people's favorites.
Old Apr 18, 2013 | 08:26 PM
Gadgetgirl's Avatar
Gadgetgirl
Thanks will check them out. Now I need to find rear shocks. LOL
Old Apr 18, 2013 | 08:28 PM
Gadgetgirl's Avatar
Gadgetgirl
Another question, if I do not replace it will it get worse with time?
Old Apr 18, 2013 | 10:23 PM
terrasmak's Avatar
Probably not, but with a difference like that i would check the bushings. Typically the alignments gets like that from bushing wear of slightly tweaked parts over time.
Old Apr 20, 2013 | 07:13 PM
AARONHL's Avatar
AARONHL
That alignment is perfect actually. You right side upper camber arm ball joint is probably weak causing the excessive camber...you might want to replace your compression rods, I noticed the caster is off, but still ok
Old Apr 20, 2013 | 08:33 PM
ian99rt's Avatar
ian99rt
I would bet with a driver in the car the left front camber would even out with the right. My front left was at -2.5 and right at -1.6 with my fat a$$ weight in salt bags in the seat. SPL csmber arms fixed that easily and now I'm -1.5 front and -2.0 rear and the car handles beautiful.
Old Apr 21, 2013 | 12:05 AM
Gadgetgirl's Avatar
Gadgetgirl
Thanks everyone for the helpful info.
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
