LSD's rear camber/traction arms
Old Jan 21, 2004 | 05:57 PM
wakaZ's Avatar
wakaZ
Default LSD's rear camber/traction arms
Just got my camber/traction arms in the other day and was wondering if anyone had some install tips.
Looks pretty straight forward, thinking about measuring the eyebolt to eyebolt on the stock arms as a starting point.
Do the rear swaybar mounts need to be removed in ordrer to take off the stock camber bolt on the inner mount?
tia
Old Jan 21, 2004 | 07:05 PM
FLY BY Z's Avatar
FLY BY Z
We did have to loosen the sway and lower it but did not remove it. Also, you do not need to measure anything. Just adjust the holes to fit and then after install, you can adjust it to spec by turning the nuts. Then tighten the lock nut.
Old Jan 22, 2004 | 05:06 AM
wakaZ's Avatar
wakaZ
Thanks FLY BY Z.
Kinda noticed the bolt that connects the inboard side of the camber arm is facing forward (head side) and looks like I would have to drop the swaybar mounts to get the bolt out.
Doing the Eibach spring install so I may as well do the arm install at the same time.
Old Jan 22, 2004 | 05:42 AM
FLY BY Z's Avatar
FLY BY Z
Heck why not switch the sway bars at the same time too?
Old Jan 23, 2004 | 05:14 AM
wakaZ's Avatar
wakaZ
Yup, that's the next thing when I do the Koni's
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
