Question about springs/coilovers
Old Jan 22, 2004 | 10:47 PM
deanG35c6's Avatar
deanG35c6
Default Question about springs/coilovers
I've noticed that most coilovers offer the same spring rate for the front and rear ends. Example: Tein Basics have 504 lbs front and rear. Springs, however, have a stiffer rear than the front. Why do they do this? Which setup is better in alleviating understeer? Do the dampers in the coilover setup have stiffer rears to offset the more neutral spring rate over stock?
Old Jan 23, 2004 | 06:54 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
good question...
We have in stalled Tein Basic / Flex and CS systems...
The cars handle better on turns and on straights...
with the CS, on acceleration the rear end seems to sit down more unless you put the EDFC on the hardest setting.
Old Jan 23, 2004 | 07:32 AM
deanG35c6's Avatar
deanG35c6
Man, Jason you get around, dude. I guess you know my intentions from FreshAlloy, but I'm a little concerned about overall driveability with the Basics. I'm contemplating waiting for the Koni adjustables, but then comes the game of matching that damper with a suitable spring. The Teins are matched from the factory, so in the long run it could be cheaper.
I just called your shop concerning the power steering cooler. Since I'll be running 245/40/18 in the front, I'm concerned about overheating the pump. I don't track my car, but at $115 its a cheap upgrade for basically my peace of mind. One of your co-workers is checking to see if it will fit the G35C.
Old Jan 23, 2004 | 07:39 AM
Jason@Performance
Performance Nissan
ah yeah... You talked to Bryant...
We have a G35 C coming in here ina few days so Im going to look and see if it will fit...
A friend of mine has a G35C and we should be meeting up later tonight, I can check and see if it will fit on hers but it is an Auto...
I have your number up here on my wall... SO I will give you a call when we know for sure...
Im sure it will fit though...
actually.. im going to call up Infiniti see if I can get the part number for the OE cooler... if it is the same as the 350Z.. it will fit...
You dont see anything in the way of the OE cooler do you? The NISMO one is a few inches longer...
Jason
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
