Brake fluid reservoir filter?
Old May 15, 2013 | 08:07 AM
03stampededak's Avatar
03stampededak
Default Brake fluid reservoir filter?
I borrowed a brake fluid tester to test for moisture content in my brake fluid before rolling out to zdayz. However, I haven't found a way to remove the filter in place under the brake fluid reservoir cap and the reservoir itself.
I could get ahold of it with pliers, but I wanted to check with you all and make sure I'm not missing something obvious.
Thanks in advance!
Old May 16, 2013 | 12:38 PM
thekinn's Avatar
thekinn
The testers that I have seen only require like a drop of brake fluid. You can use bulb syringe to get enough fluid out without having to remove the filter. They can be found in the baby department at Target or something...
Old May 22, 2013 | 06:14 AM
lbarge85's Avatar
lbarge85
you can get one out with a small pocket-sized screwdriver if you are careful
Old Sep 29, 2019 | 07:33 PM
Bat350Z's Avatar
Bat350Z
Thanks in advance!
I'm having the same issue. Unfortunately no one came out with a logical answer 😣
Old Sep 30, 2019 | 08:54 AM
dkmura's Avatar
dkmura
General & DIY Moderator
First off, you'd be better off starting a new thread, rather than resurrecting a six-year old one. But to answer more directly, I use my thumb and forefinger to reach in, twist the filter slightly and remove it. Once the plastic filter moves slightly, it usually isn't difficult to pull directly out of the master cylinder. I'm not afraid of getting silicone brake fluid on my fingers for a short time.
etkms
Apr 11, 2013 07:08 PM
ReV2Red
Feb 27, 2008 05:34 PM
mbonanni1856
Jan 19, 2005 06:04 AM
Nocturnal
Jul 1, 2003 09:32 AM
