How to tighten the nut on top of the stock spring assembly?
Old May 15, 2013 | 09:15 PM
Zoco's Avatar
Zoco
Default How to tighten the nut on top of the stock spring assembly?
Ok, so I have searched this whole section for this question of mine and I can't find a good answer to I'm going to ask it directly. I just installed my tein s techs yesterday and I put the car back on the ground and was wondering if I could tighten the top nut up while the springs are under the load of the car while it is on the ground.
The problem I ran into though is that I tried to use a deep well socket and torque it down, but that just moves both the nut and the stud that the nut must go further down on all together.
So how do I go about this, because I have limited space under the engine bay because they don't give you a huge hole to get to that nut.
?????? PLZ HELP
Also it's not like my suspension is making any noises either I just want it to be tight just in case.
Old May 15, 2013 | 09:46 PM
freddys 350z's Avatar
freddys 350z
the shaft has a flat spot to put a wrench..so use a gooseneck wrench to hold the nut and a wrench to hold that shaft and tighten it up.
also, if you have access to a pneumatic impact, it will make short work of it.
Old May 15, 2013 | 09:48 PM
freddys 350z
just to confirm, your talking about the nut on the shock shaft, right? or are you talking about the 3 studs that bolt to the car?
Old May 16, 2013 | 05:07 AM
Zoco's Avatar
Zoco
Yes I'm talking a about the main nut in the middle.
Old May 16, 2013 | 09:06 AM
freddys 350z
cool, than post #2 is what you need to do.
Old May 16, 2013 | 10:08 AM
Zoco's Avatar
Zoco
Ok thank you I will give it a try
350Z_Al
Oct 29, 2020 07:44 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
samansharif
Sep 25, 2015 12:31 PM
