Suspension all done!
Cool deal! I've been running these 255s for a while and they've been on the track as well. I don't get out on a track as often as you probably do terrasmak, so they've served me well. For the sake of a better look I do want to run a larger front. Just no sense in shelling the money out for it just yet considering I've still got some tread life left on em
Not sure how different the z's speedo readings are, but for my g35 coupe, 275/295 it seems like the fronts would be +1.89% and rears +1.55%, thus causing a pretty significant change in speedo readings. Do the front and rear differences simply add to the total difference in speedometer reading? I'm trying to see if I can do a bigger setup on my next set of tires vs my 255/35/19 front and 285/35/19 rear setup now, but I would like to keep my speedo pretty accurate
Your speedometer reading is only affected by the overall diameter/circumference of the wheel and tire size, not the width. If you go up from 17/18/19 inch wheel, you need to drop the size of your tire sizewall accordingly. This will maintain an accurate speedometer reading. Also don't forget that as you lose tire tread the speedometer reading will varry as well. You'll be going slightly faster on new tires and slightly slower on old tires +/- about 1-2 mph.
QFT ^
Thanks terrasmak, I definitely appreciate your insights, you even convinced me to just pickup a setup of kw v2 coils to replace my fortune auto coils. I have a set of 275/35's sitting around so when my 255 front's are done I'll try putting those up front and then maybe size up to 295/35 rears or something similar once my rears are done as well.
350Z_Al
Oct 29, 2020 07:44 PM
