tokico blue which springs are the best
Currently I have tokico blues shock was wondering what springs would be best for a daily driver? Im looking for 1 inch drop all around dont want to put chamber kit on it and i was looking for a middle to stiff ride with little to no bounce. Any suggestions? And thank you for your time.
^ Tein s-tech springs drop the car approx. 0.7" front and 0.6" rear. You will most likely be able to align the car without using an aftermarket camber kit (I used to have the Tein s-techs). A good spring that drops the car 1" all around would be the Eibach pro-kit. You will probably require a rear camber kit, but no front camber kit. There are a few threads on here with reviews of the Eibach springs. A search should help you out. Good luck!
For tokico blues, you are looking for a 1 inch drop
Remember anything below 1" and you need camber kits
Eibach 350Z progressive springs 1”/1” drop* on 350Z G35 drops will be higher
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
Eibach 350Z sportline progressive springs 1.2"/1.2" drop G35 drops will be higher
F: 239/400 R: 257/435
Hotchkis 350Z Linear springs .6”/.8” drop on 350Z G35 drops will be higher
Spring rates in lbs 340/330
Tein S-tech 350z (fronts are progressive, rears are linear) .7”/.6” drop on 350Z G35 drops will be higher
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
Tein H-tech 350z linear springs .3”/.2” drop on 350Z G35 drop will be higher
Spring rates in LBS 358/375
Tanabe GF210 Series 350Z progressive springs 1”/1.2” drop on 350Z G35 drops will be higher
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown)
Tanabe NF210 Series 350Z progressive springs 1.2”/1.2” drop on 350Z G35 drops will be higher
Spring rates in LBS 314/353
Swift 350Z linear springs .8”/.6” drop on 350Z, G35 drop will be higher)
Spring rates in LBS 336/364
Swift 350Z Spec-R progressive springs 1.2"/1"
Spring rates in LBS intial/final Front: 291/392 Rear: 280/448
Vogtland 350z progressive springs 1”/1” drop on 350Z G35 drop will be higher
Spring rates in LBS initial/final front 257/354 initial/final rear 285/422
H&R sport progressive springs 350Z 1.3”/1” drop
Spring rates in LBS 370/400 (peak rates only, softer initial rates are unknown)
Make your decision
Make your decision
