New coil overs + Control / Toe Arms + No Alignment =
Old Jul 29, 2013 | 08:24 AM
David_2613's Avatar
David_2613
Default New coil overs + Control / Toe Arms + No Alignment =
Ilya and I finished swapping suspension parts at midnight. I had to drive home and to work afterwards with no alignment, approx 20 miles.
I washed my car yesterday, so what you see in the pictures are pure rubber.
New coil overs + Control and Toe Arms + No Alignment =
Old Jul 29, 2013 | 09:34 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Holy chit. Thats awful.
Old Jul 29, 2013 | 09:37 AM
JaE35z's Avatar
JaE35z
lol awesome
Old Jul 29, 2013 | 03:16 PM
terrasmak's Avatar
That is why I align cars as close as possible to go to the rack
Old Jul 29, 2013 | 06:01 PM
driftsucky's Avatar
driftsucky
Goodness gracious. How EFFED UP was your alignment before. I've slammed cars and ran ridiculous and unscrupulous amounts of camber with less wear than that. LOL. Go get that fixed before your tires explode.
Old Jul 29, 2013 | 06:30 PM
David_2613's Avatar
David_2613
Yeah, it was pretty bad. I needed new tires anyways.
I went to Firestone after work and got new tires and an alignment.
Before the adjustment I had a total of 4 degrees negative toe on the rears. The *** end was all over the place at 35mph and sounded like I was in a constant drift.
Old Jul 29, 2013 | 06:34 PM
David_2613's Avatar
David_2613
As much as I liked the guys at the shop, I think I could have gotten a better alignment.
Old Jul 29, 2013 | 06:38 PM
David_2613's Avatar
David_2613
I am going to have to do some research and figure out what's going on. They maxed out the camber adjustment on the Megan control arms and I was still left with too much camber. The car is lowered only 1"
They were also confused about how the traction and toe arms worked in the rear for a while. The driver's side wheel ended up being 1/2" closer to the front of the car vs. the right wheel.
Old Jul 30, 2013 | 12:31 AM
terrasmak's Avatar
Maxed out adjustment and still to much camber, and your sitting at 1.3 , how much less do you want?
Traction arms, megan and others call them toe arms. They get adjusted to stock length, they are pretty mych useless.
Old Jul 30, 2013 | 04:44 AM
David_2613's Avatar
David_2613
I was unclear there. I was referring to the front camber which is sitting at -1.9 and -2.0.
These are installed. I had thought they would be enough to correct for the negative camber up front. Unfortunately they are maxed out and I'm still sitting at a relatively high camber which I think points towards bushings.
We did look at the bushings, but nothing was obviously out of place. Time for a much closer look.
Old Jul 30, 2013 | 08:16 AM
terrasmak's Avatar
Megan front camber arms along with many others are designed to add camber
Old Jul 30, 2013 | 11:04 AM
X.et's Avatar
X.et
You bought the wrong front camber kit, you need to switch to an SPC or SPL setup.
Old Jul 30, 2013 | 12:06 PM
JaE35z's Avatar
JaE35z
Yea megan front arms don't do positive adjustment
Old Jul 30, 2013 | 12:11 PM
David_2613's Avatar
David_2613
Ah, whoops.
In the mean time. How many miles will -2.0 camber take off of the life of my tires vs 1.1 - 1.5? If -2.0 is a suitable angle then I would just leave it.
Thanks for the help guys
Old Jul 30, 2013 | 12:47 PM
terrasmak's Avatar
-2 up front will only take 2 to 3k miles out of your tires when running proper toe and you rotate tires. Rotation is key, basically you have to flip them at around the 12k to 15k miles mark.
Old Jul 31, 2013 | 09:19 AM
David_2613's Avatar
David_2613
Thanks everyone. My new tires are not directional so I will be able to flip them.
On a side note, I think the handling is getting better from the tread wearing into camber.
I am picking up a set of 18 x 10.5 Enkei RPF1's w/ tires today or tomorrow. Going to my first AutoX event on the 10th Just have to get the new clutch put in before then.
Old Jul 31, 2013 | 11:27 AM
travlee's Avatar
travlee
Master
dang you are spending all kinds of money....... its okay i do too
Old Jul 31, 2013 | 01:20 PM
David_2613's Avatar
David_2613
I know right! Stupid addictions, relapse is a *****! LOL.
I'm done after this purchase. No.. really...I think...
I really wanted to get her ready for the track so I can get some time behind the wheel before the turbo upgrade, hopefully next year.
Old Jul 31, 2013 | 04:35 PM
terrasmak's Avatar
Hit the track, you want a lot more camber, like -2.7 up front and -2 rear, and if you hit the track you will realize that a turbo is not needed unless you want to spend more time in the pits cooling down and more time in the garage rebuilding blown motors.
Old Jul 31, 2013 | 05:33 PM
ksuberk54's Avatar
ksuberk54
How much did the alignment and putting camber and toe kits run you?
