coils or springs daily!
Whats up guys I'm new to the 350z scene came over from hondas I know I know..but I got a real job now im only 22..picked up a 04 350z roadster I daily drive it 60 miles to work and 60 miles back was wondering for a better ride quality would you go with coilovers or springs and what other upgrades would you recomend to do at the same time reasonable prices....car is completely stock
thanks!!
thanks!!
If you buy coils, be prepared to 1) spend at least 1300 or 2) don't tell anyone on this board you got them because there are still a lot of guys who respect their cars on here. And no one wants to see cheap parts put on one.. That's for the Hondas.
Umm, I think you are confused about what you are looking for, OP. In your first post you mention "better ride quality", but then, you ask about the cheapest coil overs you could find. So, do you want cheap or better ride quality? It is real hard to get both.
If you won't be putting a cage in the car then you shouldn't be tracking it, so I would go springs and shocks. You could just get some springs for now until the stock shocks blow, then replace the shocks at that point with bilstein sports. As far as spring brands go, Hypercoil is way up there, then Swift Eibach Hotchkis. I suppose as long as you go with a reputable company for springs you should be fine.
Edit: If you're gonna do something do it right the first time so you don't have to do it again.
If ride quality is your only concern then just upgrade your shocks as Terrasmak suggested
If you want the height and stiffness adjustability and then you should go with coilovers
Thanks for the suggestions I got mixed reviews on just doing springs heard it was too bouncy? Im not on a track or beating the car up 120miles a day just want a nice agressive look def dont need it slams
Some standard lowering springs paired with some Bilstein Sports will do you very nice.
http://www.tirerack.com/suspension/s...8&autoModClar=
http://www.tirerack.com/suspension/S...8&autoModClar=
Starting point
Starting point
You should read through some of the sticky threads at the top of this sub-forum to educate yourself on your new Z's suspension
Also, if you want a reference on how certain lowering springs will look on your Z, check out this thread: https://my350z.com/forum/brakes-and-...re-thread.html
And of course, please do not buy Raceland... quality coilovers will easily start at $1000-1500 in good used condition
I'm pretty sure it's too bouncy because the stock shocks will blow quickly after spring install. Like within 1k miles. I have no experience here it's just what I've read.
Many lowering springs are manufactured to run with oem/oem replacement shocks' valving, which would be completely safe to run with them with no issues
Other lowering springs state that they are meant to be run with performance aftermarket shocks (usually means the spring rate is higher) in which case you should plan accordingly or prepare for lower suspension with a horrible feel with oem/oem replacement shocks.
You should post a picture of what kind of drop you are looking for, recommendations definitely depend on how low you are looking to go. Also if possible you would want to try to ride in someone's car with a similar setup, you will lose quite a bit of comfort on the majority of setups compared to stock. And don't forget to factor in the cost of rear (and possible front) camber kits and alignment into your budget.
Chassis feels a lot tighter and more comunicative without the bone jarring I used to experience driving on less than perfect surfaces.
It's an extremely surprising case of win win when it comes to modified suspension.
Alright, so true story. I'm at lunch today, and I'm reading through modified mag. I work at a Ford dealership and they had a story on the Focus ST. So, as I turn the page, I see this....
The FIRST 2 PEOPLE I thought of INSTANTLY were Stuart and Terra. And I said to myself, I should post this just to **** them off. And I laughed to myself and kept reading. Then, low and behold, this pops up.
Aaaaaaaanywho, OP, learn about suspension (and everything else). Don't just look for cheap parts. You need to know what you want your car to do and then formulate a plan on how to do that. I am a HORRIBLE example because I have budget coils and unfunctional ride height. But, I also don't drive my car more than 1000 miles a year (and honestly I doubt I'm anywhere near that) and most of that is out of state shows. And I actually lurked the nico forums for like a solid year before I bought my 1st Z or any parts. Key is research. Another thing, do it right the 1st time. Again, I'm not a great example of that cuz I have this thing where I'd rather have the part and know full well it's capability as opposed to just making assumptions like MOST people do. But, there are quite a few knowledgeable individuals to guide you through your transition.
BETTER ride quality will be pricey for our platform. But, it doesn't sound like you have any use for coil overs. spring and strut setup may get you back to factory comfort. If they've never been done, your car's suspension could just be worn.
