Battle Version Rear Camber/Toe Arms??
Old Oct 15, 2013 | 05:18 PM
Trevor Hebert's Avatar
Trevor Hebert
Default Battle Version Rear Camber/Toe Arms??
Okay, im a bit confused about this setup. I am going to be installing TRUE coilovers and have no need for the spring bucket, so i figured i would sell my current SPC kit and use a toe control arm instead of a toe bolt.
In the pictures on the site, it doesnt look like it has a turnbuckle such as the SPC kit?
Could really use some help. Thanks
Old Oct 15, 2013 | 05:56 PM
415mm's Avatar
415mm
Professional
It's the same. I've had spc before and switched to battle version about two years ago.
Old Oct 15, 2013 | 07:27 PM
Trevor Hebert
Okay thanks. I think im going to use the Battle's for the toe arms and keep my spc camber arms and just sell the toe bolts.
Have you had any problems with the battles?
Also i see they are $175. Is this for a pair or one? Thanks!
Old Oct 15, 2013 | 08:02 PM
415mm's Avatar
415mm
Professional
Its for a pair. Make sure you get eccentric washers to replace your toe bolts. No problems btw. Best arms ive owned by far
Old Oct 15, 2013 | 09:07 PM
pyshin's Avatar
pyshin
^^^ Here's a link to some quality eccentric washers/bolts: http://www.350zhatchshocksandmore.co...%20Washers.htm
^^^That site was actually created and is run by a moderator on this forum and his kit is identical to this SPL kit (http://www.splparts.com/chassis-Z33.html#SPLELZ33) for a slightly more affordable price.
Just an fyi
Old Oct 16, 2013 | 02:42 AM
Trevor Hebert
Just an fyi
Okay thanks!
So all i should need to buy are the Battle's toe arm to replace the bucket, and the eccentric washers/bolt kit?
I already have rear camber arms and toe bolts. Do i have to keep those toe bolts or can i just sell them?
Old Oct 16, 2013 | 02:43 AM
Trevor Hebert
Okay, thanks for the help!
