some problem after installing WhiteLine diff bushings
Old Oct 25, 2013 | 01:33 AM
jdmlove1's Avatar
jdmlove1
Default some problem after installing WhiteLine diff bushings
i installed yesterday whiteLine diff bushings, one in the sub frame and front 2.. when i drive the car in normal speeds every thing is normal, much better than oem bushings.. i noticed the difference
but once i hit the throttle and try to shift quickly (power shift) i hear a noise while shifting. its like a fraction noise or something rubbing with something.. i did allot of research b4 the install just to install them right!! and also allot of research of what i will be feeling after the install..
we did remove the sub frame to change the bushings.
anybody had the same experience and then they changed something then it got fixed? any ideas what might be wrong.
Old Oct 26, 2013 | 08:52 AM
terrasmak's Avatar
Something is loose, and wow that is the hard way to do the install. I only remove the subframe if in doing subframe bushings.
Old Oct 26, 2013 | 09:18 AM
jdmlove1's Avatar
jdmlove1
okay.. fixed it.. i saw a weird marks in the shield above the joint that connects the prop shaft and the diff.
so it seems like the joint is hitting the shield. so i did a quick search using my phone (coz i was with the mechanic is his work shop) and i saw a thread in the forum, someone is saying that there should be 2 washers!!
and am WTF! there is only one washer which is the down part of the diff bushings!! there is no upper washer! so i bought a washer and kept it above the 2 front diff bushings and everything is okay!
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
