TopSpeed Pro-1 CoilOver
Old Dec 15, 2013 | 03:41 PM
05 NISMO's Avatar
05 NISMO
Default TopSpeed Pro-1 CoilOver
I'm having hard time trying to understand the pre-set / pre-load, didn't come with any manual or help from the manufacture.
I have adjusted the both L&R rear spring at the same position but for some odd reason the driver is setting much lower.
Trying to get them at stock height.
Old Dec 16, 2013 | 01:48 AM
terrasmak's Avatar
Springs arn't perfect, bushings have different stiction , front settings also effect the rear, rear settings also effect the front , shock length should be the same side to side, preload will be different. Sway bars also effect height, always disco sways when making spring adjustments.
Old Dec 16, 2013 | 03:42 AM
travlee's Avatar
travlee
Master
take it to a shop and have them corner balance the car for you
Old Dec 16, 2013 | 07:54 AM
stuartc323's Avatar
stuartc323
OP if you know what your doing listen to Terras instructions, if you dont listen to Travlee's.
Old Dec 16, 2013 | 05:08 PM
guitman32's Avatar
guitman32
On the rear I noticed the same on mine, with the drivers side having to be set slightly higher than the passenger to obtain an even L-to-R rear stance
For the fronts (and the rears if youre true coilover), assuming you dont have a helper spring, Id imagine you dont need to worry too much about the preload (assuming the manufacturer did their homework). Just set the spring snug plus a few turns. My logic is that the shock/spring combo was designed with proper piston travel (comp and rebound) without the need to significantly preload the spring to affect those values at static ride height.
If you were setting up your car, my understanding is as follows: Use your preload to set sag amount to affect usable piston stroke at static ride height (both rebound and compression - which as terramask noted can vary from side to side given all other factors equal), then use the shock body to set ride height, and subsequently corner balance. Use adjustable end-links to remove any resulting preload on the sways and align.
A good example on how good shocks dont rely on preload: The Bilstein PSS range of shocks have no adjustable body but use a helper spring, which allows you to set front ride height without preloading the main spring. This indicates that the PSS was designed from factory with shock travel to match the main spring compression at static with no need for preload adjustment. Another example stock Zs have very little preload on their front springs (eg no need for a spring compressor).
All this assumes linear springs of course.
You can use a zip tie on the shock piston to measure your sag and corresponding piston travel, but in reality the shock should be designed to work properly with minimal preload since it has adjustable shock bodies, IMO. If you arent bottoming or topping out, youre ok with the preload.
If you revised your spring rates and/or spring length, that would be a different story. Ideally in your case, youd send an email to the manufacturer asking them.
Old Dec 16, 2013 | 10:52 PM
terrasmak's Avatar
This is the best way to screw up the handling with coilovers and most people do it this way. If you want to set up and adjustable body coilover, search for some of the stuf I have written about it.
Old Dec 17, 2013 | 08:41 AM
guitman32's Avatar
guitman32
Affect.
Geez terrra, you coulda just quoted the part you dont like :0
I tried searching, you post too much. So, whats the problem?
Old Dec 17, 2013 | 07:47 PM
guitman32's Avatar
guitman32
Yawn, so ill go first then.
If your problem is youd prefer to first remove the spring, install the damper, mount wheel and set the shock body length so that you hit the bumpstops right before you rub using a floor jack, to give max piston travel before hitting the stops...id agree with you. But the bottom line is most of these mass produced model specific units are designed so all the user has to do is set spring preload to zero plus a few turns then use the shock body to determine ride height. Most manufacturer instructions call for the original procedure I outlined, not saying its optimal.
If you problem is geometry related, im all ears...
Im just trying to give this guy a starting point, not some advanced class cryptic shorthand answer.
Old Dec 18, 2013 | 12:04 AM
terrasmak's Avatar
That is a proper answer!!! Also how they should be done. Coilovers are hardly preset from the factory, they are just thrown together. Plenty of shops out there don't even know how to set them up, they do it the other way and well, they just really suck. Do most coilovers come with the proper hardware and spring length to do it the proper way, usually they do, but there are times people can not get the drop they want without up the use of helper springs ( but that's more advanced stuff)
Old Dec 18, 2013 | 06:34 PM
guitman32's Avatar
guitman32
Awesome. I think this guy now has a good starting point lol.
Old Jan 7, 2014 | 12:06 AM
ALO8's Avatar
ALO8
I was trying to make sure i have my coilovers properly setup, i read above posts and was wondering if it applies to these fortune auto as the video says to adjust height through lower bracket?
<iframe width="560" height="315" src="//www.youtube.com/embed/FHwwEn3x7Zc" frameborder="0" allowfullscreen></iframe>
Stevo Z
Oct 3, 2015 09:14 PM
