Can somebody tell me if these are factory brembos
I found this add but I believe its totally bogus I have never heard of a 15" kit for our car. I asked the guy what size wheels he had on his car he said 20" but they might fit a 17" and fit all 18" can somebody let me know how to positively verify to him that they are factory brakes. correct me if I'm wrong but I believe they are factory
http://edmonton.kijiji.ca/c-cars-veh...AdIdZ479062547
looks factory. most aftermarket kits have bracket adapters since caliper bodies are the same from one car to another (higher end manufacturers change the piston size too)
Also a 15" rotor would be heavy if only a 1piece.
Take the image and measure the rotor using the hole centers for the lugs being 5x114.3. Should be able to get close if he gives you a high res pic.
he said the rotors are 2.3" larger than factory think maybe be bought an adapter bracket from somewhere like racing brakes and bought larger rotors and kept the oem brembo callipers. he is set on them being after market i need some sort of proof he wants 3000 for them
unbelievable
looking at them and looking at other factory brembo they are slightly different where the pistons are is more distinctive more round I also did some digging and found the guys car online. the brakes are on his car but its still hard to tell
http://forums.quattroworld.com/s4s6/msgs/66102.phtml
unbelievablelooking at them and looking at other factory brembo they are slightly different where the pistons are is more distinctive more round I also did some digging and found the guys car online. the brakes are on his car but its still hard to tell
I think i figured it out I think they are off an evo 8 they look identical to these ones. Actually they are slightly different. gees I'm confused
http://www.alltrac.net/phpBB2/viewtopic.php?t=22072
For one, if I was selling a set of brakes for $3000 I'd make sure they were chuffing clean that's for sure and as has been said before, it seems like he's in a bit of a hole and struggling to dig himself out of it.
Yeah I agree with Advan, they do look like Akebonos. Not off an Evo as there is no cross over tube. Not OEM Nissan either as the shape is way off. Definitely not $3000. Good call on staying away.
