How Much Degrees Of - Camber Can You Get With OEM Spring Bucket?
Old Mar 12, 2014 | 06:18 PM
kennyy's Avatar
kennyy
Default How Much Degrees Of - Camber Can You Get With OEM Spring Bucket?
hey guys i searched everywhere and i feel i can finally make a thread because i just can't find the answer to my question and I'm hoping someone can help me.
So i recently finished my air suspension install, and the rear suspension is getting the last bit of patience out of me. So before i had the rears bagged i only had the front bagged and the rear kept static, i initially only bagged the front for a front lift on driveways,speed bumps etc etc. anyways long story short, when i was static i had megan toe arms so adjusting my camber was a piece of cake, but now that i had to put the rear buckets back on I'm running into so many problems. What do i have to do to get to -6 rear camber, i have spc camber arms...and if all else fails who can i take it to so they can do it for me cause I'm running out of patience. Im in socal thanks for any help!
Old Mar 12, 2014 | 06:42 PM
Bmurray350z's Avatar
Bmurray350z
https://my350z.com/forum/brakes-and-...ble-stock.html
Old Mar 12, 2014 | 06:48 PM
kennyy's Avatar
kennyy
thank you but thats for oem toe bolt, i have the spc toe bolt. I guess my question should of been....how much degrees of toe do i need to correct -6 rear camber
Old Nov 10, 2019 | 11:24 PM
TGMcCoy's Avatar
TGMcCoy
Dead thread bump.
Op, what did you end up doing?
Thanks!
Battleship350z
Oct 1, 2015 06:10 PM
pgZETO
Dec 8, 2014 11:51 PM
MANSU_V36
Nov 18, 2012 05:37 PM
JKC350z
Feb 5, 2007 07:36 AM
optionimports
Jun 21, 2006 06:43 PM
