powergrid endlinks review
Old Aug 7, 2014 | 04:13 PM
Justin100's Avatar
Justin100
Default powergrid endlinks review
I installed my powergrid endlinks recently,
When I had OEM endlinks on my hotchkis sway bars, ====> lots of clunking, and squeeking sounds, the endlinks have 100k on them....
When I drove and turned I heard the squeek and clunk so I was a little afraid of turning corners at high speeds with that sound.
I installed the powergrid endlinks because
1. no more clunking, squeeking sounds
2. strangely the steering wheel feels really tight now I actually have to use both my hands to turn the steering wheel, I don't know if its the characteristics of the endlinks or the mechanic torqued it like crazy....
3. turn at highspeeds with confidence.
Overall they are pricey...... 160 (front pair) + 160 (rear pair) = 320 + 50 Install = 370....
Old Aug 7, 2014 | 04:34 PM
guitman32's Avatar
guitman32
Nice review...the community appreciates it.
Now we all return to hoping that all the newbs see your thread, alas, in vain
Old Aug 7, 2014 | 11:32 PM
terrasmak's Avatar
There should be no difference in turning the wheels between the two unless they were set to bind badly.
Old Aug 8, 2014 | 03:19 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Agreed. What sway bar hole are you on in the front? Did your mechanic adjust the end links under load or with the tires hanging?
Old Aug 8, 2014 | 03:41 PM
Justin100's Avatar
Justin100
he lifted my car up in the air with the tires hanging and installed all of the endlinks,
Was this not correct? I have 30 days to come back to tell him to fix it....
Old Aug 8, 2014 | 04:58 PM
guitman32's Avatar
guitman32
Ideally it should be done with the wheels loaded so there is no preload on the bar. If he at least matched the stock length, then this would be very irregular. You didnt slam it right after did you lol
Do you mean you have to crank the wheel with effort more? You might just be perceiving the increased roll stiffness at the steering wheel. Does the wheel have the tendency to want to center itself when unwinding the wheel more now?
And you didnt say what setting theyre on...
Old Aug 8, 2014 | 06:37 PM
AdvanZ33's Avatar
AdvanZ33
http://www.powergridinc.com/pdf/Powe...structions.pdf
Old Aug 8, 2014 | 07:57 PM
Bmurray350z's Avatar
Bmurray350z
Yeah endlinks are supposed to be installed with suspension loaded. Best if done on a 4 post lift.
hulkout
Apr 28, 2017 09:00 PM
nanotech
Oct 2, 2015 05:02 AM
carid
Misc.
Sep 10, 2015 06:16 AM
robbyn
Aug 2, 2002 08:41 PM
