Rear shock mount reinstall question
Old Nov 29, 2014 | 04:53 AM
JMSpeed's Avatar
JMSpeed
Default Rear shock mount reinstall question
I just tackled the rear shocks and springs. Upon reassembling the new Bilstein shock to the upper mount, I did not have access to the tools to be able to torque the locking nut to the 20-24 ft lb per the FSM. Instead I had an allen wrench and offset box head wrench to hand tighten it as much as I could.
What's the consensus on how much torque can be applied by hand, and how would I even go about torqing to the specs with the way it designed?
Old Nov 29, 2014 | 05:03 AM
cashmoney03's Avatar
cashmoney03
Tighten it until the bushings expand to the same size as the washer. 24ftlbs isn't very tight at all.
Old Nov 29, 2014 | 05:21 AM
JMSpeed's Avatar
JMSpeed
Thank you for the fast response. I'm not quite sure what you are referring to though. Could you please clarify?
I know the locking nut sits on top of the washer that came with the new shocks, which sits on top of the OEM mount package.
Old Nov 29, 2014 | 08:26 PM
cashmoney03
Use the old german torque rating of gutentight.
Old Dec 9, 2014 | 12:18 AM
DarkCreep's Avatar
DarkCreep
Ive done this many times and just used normal fore arm strength, never had a problem.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
StateNuke08
Oct 31, 2015 05:01 AM
Paul.
Oct 16, 2015 07:34 PM
CJs_Z33
Sep 18, 2015 12:06 PM
Suffolk350z
Sep 13, 2015 02:43 PM
