Will +25mm SF-Winnings clear Stoptechs?
Old Feb 9, 2004 | 12:09 AM
jran76's Avatar
jran76
Default Will +25mm SF-Winnings clear Stoptechs?
I am trying to decide on new wheels, and I am curious if anyone knows if the 19" SF Winnings with a +25mm (A) offset will clear the Stoptech 13" kit with a 8.5" wheel in the front.
Also, I would go with the +29mm (B) offset on the rear, I am pretty sure it will clear the non-brembo rears, but if someone thinks otherwise feel free to chime in....
The other wheels I am considering are 18" Nismo wheels (I will get these if I go with 18" wheels) with +25mm offset F/R, or 19" CE28N's with +22mm offset F/R.
Can any vendors get the 19" Winnings or CE28N's?
Old Feb 9, 2004 | 07:19 AM
J Ritt's Avatar
J Ritt
Jran,
I'm not sure about that fitment. We have downloadable templates on our website. I'm sure one of the wheel vendors on this board has a set, or another member can probably check wheel fitment for you. Let me know when you find out though, and I'll add it to our list of wheels that fit. Thanks for the support!
Old Feb 9, 2004 | 08:05 AM
jran76's Avatar
jran76
I am going to find out, so I will let you know.
Can someone with stock non-Brembo fronts and 17" stock wheels measure the distance between the caliper and the wheel?
And, if someone has stock non-Brembo fronts and SF Winnings in this size can you do the same?
I only have a few mm's between my Stoptech's and the stock 17" wheel.
I know this is a pain, but help a fellow Z owner out....
I need new wheels.
Old Feb 9, 2004 | 05:54 PM
MATIX's Avatar
MATIX
Let me know when you want to order, i'll get you the cheapest price on either hte Winnings or CE28's
Old Feb 12, 2004 | 09:51 AM
jran76's Avatar
jran76
Bump. Anyone?
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
