Watch me suffer suspension hell!
Old Mar 30, 2015 | 05:57 PM
Chrismx5's Avatar
Chrismx5
Default Watch me suffer suspension hell!
So this past weekend, I managed to hit a wall. Thankfully the damage isn't TOO bad..
However - as you can see the suspension took a hell of a beating.
I will be upgrading instead of repairing. So everything, once complete will be new.
Thankfully the coilovers and camber arms in the front are fine!
Along with new arms all around, I will also be getting a Parts Shop Max angle kit, really for no reason other than, May as well make the most of a shi**y situation =]
Old Mar 30, 2015 | 07:45 PM
Spike100's Avatar
Spike100
^^ I don't see any problem areas on the picture you posted. Can you circle the areas you describe as problematic?
Old Mar 31, 2015 | 11:04 AM
Chrismx5's Avatar
Chrismx5
Apologies - the photo doesn't really show too much, a bit of rippling in the body work, cracked rear spring perch, cracked front knuckle, bent lower control arms
Old Apr 6, 2015 | 05:40 PM
Chrismx5's Avatar
Chrismx5
Okay! So I have found the root of my problem, or rather, one of my problems! A cracked rear spring bucket!
I have also managed to suss a Parts Shop Max super angle kit, I figured why replace, when I can upgrade!
350Z_Al
Oct 29, 2020 07:44 PM
