HELP! Toe issues.
Old Jun 2, 2015 | 05:07 PM
SlammedZ60's Avatar
SlammedZ60
Default HELP! Toe issues.
Alright, so I'm looking for other Z's that are on air with more than -8 degrees of camber. How are you correcting toe? I already installed the SPC toe bolts and slotted the spring bucket mount. I'm in desperate need of some help. If you would be kind enough to share what you're doing to correct it, it'd be greatly appreciated. Thanks!
Old Jun 2, 2015 | 05:37 PM
travlee's Avatar
travlee
Master
does it really matter if you correct toe? you are going to burn through tires with that camber anyway
Old Jun 2, 2015 | 06:31 PM
StevSam's Avatar
StevSam
I've been having the same problem. My front inner tires are wearing out too fast!!
Old Jun 2, 2015 | 06:41 PM
NismoDude's Avatar
NismoDude
see a podiatrist?
Old Jun 3, 2015 | 02:00 PM
SlammedZ60's Avatar
SlammedZ60
bump
Old Jun 3, 2015 | 04:39 PM
guitman32's Avatar
guitman32
It sounds like you are talking about the rear...not familiar with geometry at that extreme, but my thought would be to either:
-buy the SPL adjustable mid-links w/spring bucket (call to verify it has the range you need)
-convert to coilover in the rear and replace spring bucket with the adjustable toe mid-links
-modify your OEM spring bucket (RIP)
Old Jun 7, 2015 | 03:36 PM
labelworkshop75's Avatar
labelworkshop75
Solution. Stop running -8 degrees camber
Fixxxercask
Nov 9, 2015 11:10 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
apex locator
Oct 6, 2015 05:58 PM
z33z_nutz
Sep 23, 2015 07:22 PM
