On another note, if you don't mind, were your subframe bushings shot? How long did it take you to take the subframe out beginning to end, in hours?
I ask because half of my rear is still apart for an SPL rear diff. bushing install and I just inspected all of the rear bushings, most appear fine, but two need replacement. I'm considering dropping the frame to get at all of them while I have the time and opp.. Not to many people drop the frame.
To get it all out if you have 2 people can take as little as 30 minutes and up to an hour
My bushes were sort of ok and would have lasted a few more years but my old gtr had solid bushes and I really liked the way it felt so I was going to put these in regardless .
The slowest part of the day was cutting the old bushes out , I recommend making 3-4 cuts in each bushing and then bashing them out
Do not burn them out as you will warp the aluminium on the subframe
Pressing the bushes in was easy once you have a press
You can do this with a dead blow hammer I have heard , I tried it for a second and said life's to short so went to the press .
In total with the cutting we spent 5 hours but that was because of having to go and pick up tools etc
If we do it again I would confidently say we could do it in 3 hours
I will install my diff bushes next week as I ran out of time that day
Spl still has not replied to me unfortunately....its a shame .
The car feels ok with the configuration i was forced to use however I am yet to hit the track in anger as yet so we will see .
There is absolutely no increase in noise with these bushes , there are some thin rubber pads included with the bushes and I used those so I guess they did their job.
I'm assuming when i do the solid diff bushes I will get some more noise
