Guidance on alignment please
Old Jun 12, 2015 | 07:36 AM
motormike87's Avatar
motormike87
Default Guidance on alignment please
Hey guys - I've done all the searching I could and read and re-read JasonZ's post on suspension, and I'm still a bit lost when it comes to getting an alignment done on my Z. Would really appreciate any guidance.
The car is a 2008 350Z, lowered on Eibach Pro-Kit, with Eibach camber arms and toe bolts installed. The car has 18" wheels wrapped in 275's on the rear and 255's up front (F: 18x8.75 +20 / R: 18x9.75 +20). With this setup, am I OK to just get a regular alignment done at a tire shop, or should I provide them with alignment specs outside of what the factory specs are? If so, any suggestions on camber/toe specs I should be within? The car is a daily driver. Thank you
Old Jun 12, 2015 | 08:12 AM
terrasmak's Avatar
Some people may want to post full wheel specs, they could be a factor for alignment
Old Jun 12, 2015 | 08:29 AM
motormike87
Good point.
Front: 18x8.75 +20
Rear: 18x9.75 +20
Old Jun 12, 2015 | 09:49 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Generally speaking, factory specs are fine for street/DD. A little negative camber (1-1.5 max) for performance usage is fine, just don't go overboard so as to keep your tires happy.
I deviated to -1 (extra degree out back) - a good compromise that has helped plant my rear 275s nicely with no appreciable added wear.
But then, I have three sets to alternate between so who can tell?
Old Jun 12, 2015 | 10:17 AM
guitman32's Avatar
guitman32
Tell them you want factory specs, with front toe on the minimum end of the spectrum (closer to zero). Tell them you want a printout, and to review it before they put your car down.
If at all possible I recommend developing a rapport with the actual tech who is performing the alignment, chances are he likes cool cars as well.
Old Jun 12, 2015 | 11:13 AM
terrasmak's Avatar
Factory specs rear , run -1.7 to -2 out back and that is within spec. Then match the front camber to the rear, this will keep you from wearing out the outside of the tires when you play , and give less understeer
emooheo
Oct 14, 2015 08:58 AM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
