Advice needed - Brake discs and pads for Brembo system
Old Sep 5, 2015 | 05:44 AM
sry110's Avatar
sry110
Originally Posted by guitman32
You need to re-bed your pads and rotors. Do two full cycles which should take care of the uneven deposits on the rotors you describe, an in turn hopefully get rid of your vibrations.
A stuck piston wont cause vibration or pulsating in itself, only a steering pull and overheating which can then lead to warping and uneven deposits, possibly causing vibration.
If re-bedding doesnt fix the pulsating, then likely your rotors are warped.
Thanks for the advice. I am not experiencing steering pulling one way or the other, nor have I noticed any excessive heating. I may try scuffing up the brake disc surfaces and re-bedding the pads at this point.
Old Sep 5, 2015 | 12:09 PM
guitman32's Avatar
guitman32
Wouldnt bother removing and scuffing, thats more for getting proper bedding layer between the pad and and a used rotor, but will not do anything that a couple of bed-in cycles wont already do in terms of removing surface deposits on the rotor surface that may be causing vibrations.
Old Sep 7, 2015 | 06:16 AM
sry110's Avatar
sry110
Ok, got it. Well, I went out and did a bed-in cycle and it did not change anything. I'm thinking my next step is to take the pads out and make sure they are wearing evenly so I can rule out a stuck/seized caliper piston. If the pads and pistons look good, I plan to replace the rear rotors and see how that goes. Then I will move onto the front rotors if need be.
Old Sep 9, 2015 | 12:43 PM
kham25's Avatar
kham25
Originally Posted by sry110
Thanks for the suggestion, I will surely consider those pads! I'm pretty set on Centric blank rotors this time around as they should not give me any problems, and should be easier to resurface (versus slotted rotors) if I ever needed to at some point.
I remember back in ~2011 when I had the Brembos installed, I was on my way back from the shop that did the install and applied the brakes and they grabbed very severely and then seemed to let go. I was not going through a bed-in process but should have been (I wasn't thinking about the fact that the shop did not take the car our for a test drive / bed-in drive after installing the fresh rotors). The pads were lightly-used OEM Brembo pads that came with the calipers. It's possible that at that time the OEM Brembo pads left a patch on the rotors....but I can't remember if the vibration/pulsation issue started at that time or soon after.
Later I swapped the OEM Brembo dusters for StopTech Street Performance pads, which I currently have on the car. IIRC the problem intensified (if not started altogether) with these pads.
Another possible cause for the problem is that most times after I wash the car, I pull it right back into the garage where it will often sit 1-2 weeks before I move it again. The pads become noticeably stuck to the rotors, like I have to slip the clutch a bit giving it gas to break the bond between the pads and rotors the next time I drive it. I'm thinking I need to do the following:
* Replace all 4 rotors
* Leave StopTech street perf. pads in place (they only have ~3000 miles on them)
* Execute proper bedding-in process
* Take car for a drive after each washing to remove any residual water from the pad-disc interface before putting the car back into short-term storage.
Honestly, one of the reasons I rarely drive the car is because the brakes feel so unsettling. I would like to start enjoying the car again so maybe putting in this time+money will pay off.
Experienced the pad sticking to the rotor last week for the first time. I washed the car and it was about 1 week before driving. God lord the brakes made the loudest clanking noise when selecting reverse gear. I saw the Pad rusted Imprint on 3 rotors. I did some really hard braking and luckily that took care of the pad imprint on the rotors.
Just did the Brembo swap 2 months ago and never had this noise with the stock 07 brakes.
Stoptech slotted rotors and Hawk HP pads on the brembo.
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
PLAYDIRTY
Oct 12, 2015 07:45 AM
codek
Sep 27, 2015 03:21 PM
