Best Springs for Launches
Old Feb 11, 2004 | 02:42 PM
VQ35DES's Avatar
VQ35DES
Default Best Springs for Launches
What should I get for the best lauch?
Tien S
0.7 Front | 0.6 in the Rear
Spring rate: 386lbs/inch front
402lbs/inch rear
Tien H
0.3 Front | 0.2 Rear
Spring rate: 358lbs/inch front
375lbs/inch rear
RS-R Downsprings
0.6" Front | 0.6" Rear
Spring Rate: 345lbs/inch front
417lbs/inch rear
Old Feb 11, 2004 | 05:00 PM
MY350Z.COM's Avatar
you want a soft rear
so that the car squats when you launch
which allows it to get better traction
Old Feb 12, 2004 | 12:06 PM
UnderPressure's Avatar
UnderPressure
but.....
The shock must have enough rebound dampening to keep the rear "squated". Otherwise you get a pogo effect w/ a soft spring and little rebound.
The idea is a quick, aka soft, compression stroke to help weight transfer towards the rear. Then a slower, aka stiff, rebound stroke to allow the car to slowly return to height once the car has overcome interia vs available traction.
Ideally you would like to run a setup that allow seperate compression and rebound adjustments. However very few are available, and the few that are out are expensive.
I don't think anyone has done any testing to determine the idea drag setup for the Z, yet...
Old Feb 12, 2004 | 03:43 PM
JonathanG35's Avatar
JonathanG35
any guesses on how i should set my edfc.
0 front 14 rear??
i usually drive on 0 front 0 rear
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
Conway_160
Drag
Sep 29, 2015 08:07 AM
