Rear right toe even worse after allignment?
Old May 16, 2016 | 07:51 AM
ukraini9mofo's Avatar
ukraini9mofo
Default Rear right toe even worse after allignment?
Hey guys, so I recently (week ago) installed s-tech springs and today went to get alignment done at Firestone, below is the printout and it looks like while rear toe adjustments are in spec now the Right Rear Camber became worse (from -3.6 to 4.2).
Looks like I will need to get camber kit to correct this, but has anyone ever had the camber become worse after alignment visit (does it signal a poor tech or could it become worse as he pulled the toe setting in spec)
Thanks for your input
Old May 16, 2016 | 07:54 AM
travlee's Avatar
travlee
Master
get the spc toe bolts and the rear camber lockout washer... the lockout makes them use the after market arm to adjust camber
Old May 16, 2016 | 08:13 AM
ukraini9mofo
Thank you for info, some noob questions
1. So I should get bolts only? I was thinking I need the camber arm as well?
2. The tech said he couldnt adjust the eccentric bolt on the rear, its not long enough, thats why you suggested the bolt?
Thank you very much .
Old May 16, 2016 | 08:15 AM
travlee's Avatar
travlee
Master
get it all. the toe bolt give more adjust-ability
http://www.b2autodesigns.com/product...e167b6a9a0a290
there is some good reading on this one
http://350zhatchshocksandmore.com/Lockout%20Washers.htm
Old May 16, 2016 | 09:56 AM
ukraini9mofo
Sounds good will do, as far as running -4.2 (0.5 off the spec) and -2.6 (2.1 off spec) will that cause SEVERE premature tire wear or as long as toe is within spec its ok to leave it like that ?
Z33E
May 4, 2016 06:19 PM
Gabriellajergos
May 2, 2016 07:06 PM
NFAC
May 1, 2016 05:01 PM
NecktieNinja
Apr 26, 2016 06:57 PM
